TextRegionUtilities - Could not load file or assembly 'WriterRegion
TextRegionUtilities - Could not load file or assembly 'WriterRegion - Cannot install or disable TextRegionUtilities - Messaggi
#1 Pubblicato: 14/10/2021 06:54:45
timgow
timgow
0 apprezzamenti in 27 post.
I wished to install TextRegionUtilities but this failed, now I can't enable or disable it from the local Plugins list.
Please help, I don't know the next move.
Tim
#2 Pubblicato: 14/10/2021 08:21:56
Gruppo: Moderator
If you install WriterRegion everything should works as intended again.
#3 Pubblicato: 14/10/2021 11:10:48
timgow
timgow
Hello Davide,
Thank you for lookin at this issue.
WriterRegion is installed. I uninstalled WriterRegion, closed, installed WriterRegion, closed, reopened but unfortunately still get the error.
Tim
#4 Pubblicato: 14/10/2021 11:14:36
timgow
timgow
Davide,
The enable & disable were greyed out but I didn't realize that the dustbin was active; I deleted and reinstalled, all ok now.
Many thanks,
Tim
