Function called with matrix arguments get wrong answer
Function called with matrix arguments get wrong answer - Function called with matrix arguments get wrong answer - Messaggi
#1 Pubblicato: 19/11/2012 10:22:33
jmc
jmc
0 apprezzamenti in 5 post.
See the attached sheet.
The call to Vo() with matrix arguments should get the same answer as the individual evaluation, also included in the sheet, but it does not.
Vreg.sm (16 KiB) scaricato 1424 volta(e).
#2 Pubblicato: 20/11/2012 05:02:52
Gruppo: Moderator
No, it is not a bug - just a SMath feature. You divided a scalar (RU) with a matrix (RL), that is wrong. Reciprocal of a matrix gives its inverse, not the reciprocal of its elements as you wanted.
Please see the attached corrections
Vreg-corr.sm (20,21 KiB) scaricato 1452 volta(e).
#3 Pubblicato: 20/11/2012 06:24:32
jmc
jmc
Thanks for the correction. This one might be a good addition to a Gotya section on the wiki if it is not already there.
