[SS-2439] 6179 Crash
[SS-2439] 6179 Crash - Unable to Recover - Messaggi
#1 Pubblicato: 09/01/2017 09:43:05
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
Hi
Attached SS file (98.6179) crashed and unable to recover.
Max Rainfall Analysis.sm (0 B) scaricato 1409 volta(e).
#2 Pubblicato: 09/01/2017 11:40:26
"Root element missing"
Work sheet is empty: it was not saved most probably because some
character not allowed in the file name... why crashing Smath ?
Normally, Windows would issue a message telling "not allowed filename".
Can't help more: reconstruct from blank, simple work sheet name.
Any other failure of 6179 ?
#3 Pubblicato: 09/01/2017 12:03:15
Gruppo: Moderator
Totally empty file. AFAIK is the first case since a long time.
Any clue about what could have triggered the crash? (since the last successful save, have you done/added/deleted something unusual, some action while saving?)
NDTM Amarasekera 09/01/2017 20:55:00
#4 Pubblicato: 09/01/2017 12:27:27
NDTM Amarasekera
NDTM Amarasekera
I was making some minor changes to the working file.
When trying to select and move some assigned variables, then suddenly got the "usual warning that Smath does not respond".
When clicked to quit, got an option to save it and clicked to save.
The file closed, but then unable to reopen any more (showing the above error message).
Davide Carpi 09/01/2017 13:55:00, Andrey Ivashov 09/01/2017 13:44:00
#5 Pubblicato: 09/01/2017 13:43:40
Gruppo: Super Administrator
Thank you for the report! I thought we have no such issues anymore...
To finally fix it I think SMath Studio should never immediately replace files on Save, but always create a new file next to existing one and replace old one with a new file only in case it was correctly saved.
Will implement this logic asap.
I hope you have a backup of this worksheet as there is no any possibility to restore it using a file you have attached.
Davide Carpi 09/01/2017 13:55:00, NDTM Amarasekera 09/01/2017 20:55:00
#6 Pubblicato: 09/01/2017 14:00:58
Alexander O. Melnik
Alexander O. Melnik
127 apprezzamenti in 498 post.
Gruppo: Moderator
Hi
Not that it will help you now, but AutoVer http://beanland.net.au/autover/ with 1 TB hardrive will make your workflow very flexible in regards to data backup and saving numerous versions of a file.
PM if you decide to try it and need help with setup.
NDTM Amarasekera 09/01/2017 20:55:00, Davide Carpi 09/01/2017 14:08:00
#7 Pubblicato: 09/01/2017 17:04:27
Attached is the US rainfall model.
Plug your XY data for consolation !
Stat US Rainfall.sm (18,52 KiB) scaricato 1357 volta(e).
#8 Pubblicato: 09/01/2017 20:57:43
NDTM Amarasekera
NDTM Amarasekera
Fortunately, I had a copy (slightly different), but was able to manage.
Thank you all!
Davide Carpi 09/01/2017 21:09:00, Andrey Ivashov 10/01/2017 15:49:00
#9 Pubblicato: 14/02/2017 15:18:26
emothman
emothman
0 apprezzamenti in 1 post.
I just had the same problem. Build 6179. Erased a large SMath file on a crash. Same situation as ndtma. I am hoping I have it backed up. There is no way to recover it, correct?
#10 Pubblicato: 15/02/2017 05:59:43
Gruppo: Moderator
If the file contains some data, something could be recovered. If the file is empty (0 byte) there isn't way to recover it.
#11 Pubblicato: 15/02/2017 09:20:35
From observations:
The case of Legendre crashing was no problem to recover because it was a crash between
5346 & 6179. Much differently, if a crash occurs while working on a new document, the
document is not saved as it was before crashing ... "root element missing". Mathcad 11
didn't have provision to backup the work sheet as far as coding was OK before a crash.
The question is: can it be done, does such backup existS ?
Answer is YES
OriginLab [the main software in Medical/Pharmacokinetics] has this type of backup.
But: OriginLab is not an "Equation editor" like Mathcad, Smath
There is another case of Smath not recovering file, from observation.
In Mathcad, an image is created from the work sheet or recovered from file.
In Smath, once an image has been successfully plotted in the work sheet, it resides
in its own system and can be recalled from the named image. But if the image has not
completed the plot, the entire work sheet can't be saved and is not saved.
So, clicking on the file name from the C:\ ,,,, "root element missing" no file.
Eventually, an Smath document may become large in size an quite involved in maths
for instance lot of 'maple stuff'. As the work progresses, wise to make copy and
work on the copy and progressively save the copy as the original.
Have a good day.
#12 Pubblicato: 20/03/2017 03:49:55
m
m
0 apprezzamenti in 4 post.
Hi all, I seem to have the same issue. Tried to open my file the next day since the last time I worked on it but gave me error that "Root element is missing". Tried to use the Smath file recovery and it gives me error "Operation aborted: Not enough Data to recover or wrong file type". Filename is still the same as it always were, last thing I did on it when I worked on the file was adding a simple 2d plot, don't know if that might have caused it ?
Is there any way to recover the file since the last discussion on this topic? What is worrying me is that the file size changed to "0 kB" ...
#13 Pubblicato: 20/03/2017 07:52:55
Gruppo: Moderator
Unfortunately the file is empty so there's nothing to recover; currently only chance is to have a backup copy somewhere.
Last edit on the working worksheet was made with current version (SS 0.98.6179)?
#14 Pubblicato: 22/03/2017 03:37:09
m
m
Ah f*@, wished i made that backup copy.. Yep, have version SS 0.98.6179.
