Can smath issolate a var
Can smath issolate a var - Can smath issolate a var - Messaggi
#1 Pubblicato: 28/12/2021 10:57:43
khairfactory
khairfactory
0 apprezzamenti in 1 post.
For example
x+y+z=0
And now want to issolate Y.
y:=-(x+z)
Does smath know how to do that? And if so, is it capable of doing simplifications when doing so with more complicated equations?
#2 Pubblicato: 28/12/2021 11:18:50
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
You can use Maple Tools or Maxima plugins for this.
Links:
1. Maple Tools
2. Maxima Plugin
#3 Pubblicato: 28/12/2021 11:58:16
x y z=0
And now want to isolate Y.
y:=-(x z)
Does Smath know how to do that? And if so, is it capable of doing simplifications when doing so with more complicated equations ?
... more complicated functions YES, attached some examples.
Welcome to Smath Community ... Jean.
Contour SOLVE AstroidHyperbola COLLECT FindRoots Copy.sm (139,44 KiB) scaricato 1308 volta(e).
#4 Pubblicato: 28/12/2021 14:48:20
Yes, this worksheet is "pluginless" and can isolate expressions from an equation in some cases.
isol_n2e.pdf (52,97 KiB) scaricato 696 volta(e).
isol_n2e.sm (73,81 KiB) scaricato 1240 volta(e).
For instance, it works also in the SMath in the cloud: https://en.smath.com/cloud/worksheet/HpYWFrCC
Simplification and isolation aren't the same. The exposed concept can be extended to develop a series of rules to apply to simplify expressions for some type of 'simplify' function, or rules can be added to solve more complicated equations.
churichuro 28/12/2021 16:22:00, João Felipe Seráfico Melo 28/12/2021 16:34:00
#5 Pubblicato: 28/12/2021 16:23:44
churichuro
churichuro
29 apprezzamenti in 79 post.
o_o
Alvaro 28/12/2021 17:19:00
#6 Pubblicato: 28/12/2021 16:38:51
7 apprezzamenti in 62 post.
Razonar, that was mindblowing
#7 Pubblicato: 28/12/2021 17:33:22
Gruppo: Moderator
This is very good homebrew function. Thanks Razonar.
And now this is the part where Jean steps in and post something totally irrelevant.
Alvaro 28/12/2021 22:52:00
