Solving Symbolic Function
Solving Symbolic Function - Pls help me to find my error - Messaggi
#1 Pubblicato: 22/11/2023 17:37:30
Jonah
Jonah
0 apprezzamenti in 2 post.
i need to solve the diff the funktion q.total(t.0) to find its maximum value. It alsways says t.0 not defined. What do I do wrong? Pls help.
Fin-Heatexchanger.sm (28,84 KiB) scaricato 1502 volta(e).
#2 Pubblicato: 23/11/2023 04:33:55
Gruppo: Moderator
Direct answers to questions are more beneficial than no-meaning replies.
You don't need to ignore units, if possible never do that.
If unit ignore suggestion comes from Jean, especially ignore it.
He is notorious being wrong with engineering problems.
If it comes from {mkraska, Razonar, uni, etc} you can take it serious.
Fin-Heatexchanger_solved.sm (36,13 KiB) scaricato 1481 volta(e).
#3 Pubblicato: 23/11/2023 16:10:04
Jonah
Jonah
Thank you very much!
#4 Pubblicato: 23/11/2023 19:53:44
I need to solve the diff the function q.total(t.0) to find its maximum value.
As given you have the range of minimum values.
For min/max of function ... Golden Ratio.
#5 Pubblicato: 24/11/2023 03:51:18
Gruppo: Moderator
Sometimes general numeric solvers; solve(), roots(), FindRoot(); struggle with functions involving diff(), int(), sum(), profuct(), if(), cases(), etc.
In your case solve() could answer it. There are some situations which can't be answered by general numeric solvers.
Usually al_nleqsolve(), maple() or Maxima() can solve them.
