1 pagine (5 elementi)
Using Dynamic Assistance problem - Messaggi
Sorry, if this was mentioned before. I will do that again, just in case.
When the Dynamic Assistance is active, and when you type, say
10m
you will get
Dynamic Assistance was not activated. Pressing [BACKSPACE] and iserting "m" again, Dynamic assistance will be activated
10m
you will get
Thank you, Radovan.
Actually, I know about this problem. Will try to fix it before next version will release.
Regards.
Regards.
You are welcome
I was just surprised nobody reported this here at the Forum.
Hello.
Fixed.
Pressed keys: 2 0 c m [TAB] + 3 m [TAB] =
Best regards, Andrey Ivashov.
Fixed.
Thanks Andrey,
I checked out in 0.88, because I forgot that.
In 0.88 this will work
20cm[TAB]+3cm[TAB]=
but this will not (the same you presented in the animation)
20cm[TAB]+3m[TAB]
After the last [TAB], we are redirected to another region.
This is fixed now.
20cm[TAB]+3cm[TAB]=
20cm[TAB]+3m[TAB]
This is fixed now.
