XY GRAPHS VERSUS ZEDGRAPH
XY GRAPHS VERSUS ZEDGRAPH - Lines are broken in Zedgraph - Messaggi
#1 Pubblicato: 24/06/2023 20:01:55
RegRetired
RegRetired
8 apprezzamenti in 144 post.
The attached files show the same calculation plotted in both the SMATH XY graph and a ZEDGRAPH. The lines are not as smooth in the ZEDGRAPH. Is this a quirk of ZEDGRAPH, or do I have some setting incorrect.
Both .sm and .pdf files are provided. The scale of the pdf must be enlarged to see the difference in the two graphs.
Thanks,
Reg
Reg CurryLoveland, CO
#2 Pubblicato: 24/06/2023 21:51:15
The attached files show the same calculation plotted in both the SMATH XY graph and a ZEDGRAPH. The lines are not as smooth in the ZEDGRAPH.Is this a quirk of ZEDGRAPH, or do I have some setting incorrect.
You plot the same data set on different plot ranges.
Make the two graphs consistent, for immediate comparison.
#3 Pubblicato: 24/06/2023 23:02:48
RegRetired
RegRetired
Try these.
NOTE: Arial 8pt in XY does not look the same in ZEDGRAPH.
#4 Pubblicato: 24/06/2023 23:12:43
Gruppo: Moderator
Sorry for the huge screenshot.
Its due to line and symbol settings of traces.
Changing them will provide smoother line.
GRAPH COMPARISONS_smooth.sm (39,62 KiB) scaricato 1500 volta(e).
Click to enlarge
#5 Pubblicato: 24/06/2023 23:35:47
RegRetired
RegRetired
Thanks much! That helps.
#6 Pubblicato: 25/06/2023 07:40:06
Your X_Y plot was spoiled.
If you click in the graph region and move the pointer,
it freaks the X & Y ranging ... your delivered 1rst attachment.
Zedgraph is more traditional of Bode plots.
GRAPH COMPARISONS_smooth.sm (39,62 KiB) scaricato 1421 volta(e).
