Plotting strings
Plotting strings - Messaggi
#1 Pubblicato: 25/05/2021 20:10:14
hanskl
hanskl
7 apprezzamenti in 158 post.
Hi!
When I want to plot text/strings, I add mat(1;5) to my graph. Strings usually has top left justification.
Is it possible to set justification as the sixth element of the matrix?
#2 Pubblicato: 26/05/2021 03:22:32
hanskl
hanskl
Is it possible to set justification as the sixth element of the matrix ?
No need AFAIK.
Hello Jean,
Take a look at the attached image. I want C to have top right justification, and B bottom right. I could just offset the coordinates for a quick fix, but when I change the zoom level that will not work.
Best regards,
#3 Pubblicato: 26/05/2021 09:11:04
Hello Jean,
Best regards,
For fixed rotation, you can get inspired from the attached.
Smath is not a CAD, but from little it does so much.
This W Truss originates from Ioan [SS 5346 ?]
End result from multiple collaboration [Alyles, Carlos, Jean].
Next from you: *.sm document.
Utilities XY [Draw Truss Labels ZOOMED mode].sm (26,56 KiB) scaricato 1515 volta(e).
#4 Pubblicato: 26/05/2021 10:39:47
hanskl
hanskl
Jean,
Your example seems to work well when zooming out. When zooming in the labels starts getting further appart fram the drawing.
I was hoping maybe this was something the developers could incorporate in an upcoming release.
Best regards,
#5 Pubblicato: 26/05/2021 14:24:37
hanskl
hanskl
You are asking a CAD functionality that does not have much interest.
This triangle has some curious relationship.
Most probably each figure will have more surprises + rotation.
What is the interest of zooming a triangle ?
That one, you can zoom/rotate at will for [Area/Perimeter/CG]
[Area/Perimeter/CG] for any figure of XY vertices.
Where are you in your design ? ... Jean.
Jean,
I was just puzzling around with trigonometry. I never seem to remember the trigonometric relationships, so rather than googling 'trigonometric functions' all the time, I figured it would be fun to try to make something in SMath.
Attached is the "project" I was fooling around with. I tried to plot an angle (L) in all the corners that were 90°, but because of the significant round-off errors I skipped that part.
Best regards,
Trigonometry.sm (39,97 KiB) scaricato 1631 volta(e).
#6 Pubblicato: 26/05/2021 15:42:27
Gruppo: Moderator
This is a very good example.
Nice job, kudos to your project.
#7 Pubblicato: 26/05/2021 16:16:54
hanskl
hanskl
Thank you, far too kind!
Best regards,
#8 Pubblicato: 26/05/2021 18:54:42
hanskl
hanskl
Your zoomed triangle is pure success from brute force refactoring.
Sorry for the 5 hours power failure from unusual strong wind.
Thanks for this nice project ... Jean
Trigonometry.sm (49,98 KiB) scaricato 1745 volta(e).
I guess zooming in and out on the plot could be avoided by resizing the triangle within the plot.. and that way shifting/aligning the labels manually will work just fine.
Best regards,
#9 Pubblicato: 27/05/2021 08:04:45
Last brick in the wall for that one.
Medians [med] approximate, not from calculations.
More maths added for convenience.
Thanks for that superb Classroom ... Jean
Utilities XY [Draw ZOOM Triangle].sm (20,36 KiB) scaricato 1483 volta(e).
#10 Pubblicato: 28/05/2021 07:10:15
hanskl
hanskl
Jean,
Very interesting! Thanks for the insight.
Best regards,
#11 Pubblicato: 28/05/2021 10:57:10
... added rotation of a new triangle.
Take care ... Jean
Utilities XY [Draw ZOOM Triangle] Copy.sm (47,22 KiB) scaricato 1544 volta(e).
