1 pagine (15 elementi)
Plugins crash in Smath Studio 0.99.7679 - Meta TagsEditor and Text RegiosUtilitues plugin crash - Messaggi
I will update these plug-ins soon.
WroteI will update these plug-ins soon.
Is it possible to add a button to temperally disable plugins so they don't get loaded at startup but still can be checked for update?
WroteWroteI will update these plug-ins soon.
Currently it is not possible.
mMath Files and Knovel Meta Tags Editor plug-ins fixed.
Thank you.
Thank you.
But the Text Region Utilities plugin keeps crashing
Carlos
Thank you.
Carlos
WrotemMath Files and Knovel Meta Tags Editor plug-ins fixed.
When installing them through plugin manager, both of them shows "plugin installation fails"
WroteWrotemMath Files and Knovel Meta Tags Editor plug-ins fixed.
Looking at the screens hot you provided it seems that you have plug-ins installed by manual copy of dll files.
You need to delete such plug-ins first and then install then from Extension Manager.
WroteBut the Text Region Utilities plugin keeps crashing
Thank you, I'll try to fix it ASAP.
WroteWroteBut the Text Region Utilities plugin keeps crashing
Davide, I've forgot to make some reviewed Fields public, so it was just impossible to fix the plug-in. Now it is done.
Fixed.
Davide Carpi 14/01/2021 04:07:00
UNI's EFI plugin is crashing too.
My new portable install has no plugins at the moment
Should I remove it per 0.99.7610 is available
WroteUNI's EFI plugin is crashing too.
Strange. Just checked EFI plug-in - it loaded correctly in my SMath Studio installation.
Thank you Andrey
WroteStrange. Just checked EFI plug-in - it loaded correctly in my SMath Studio installation.
As you see from the screenshot above, I'm using version 7610 (portable version). I uninstalled the plugin and reinstalled. The install went well and no errors. However, once I restart SMath, the error pops back up.
Could it be a portable version issue?
