Graphing Problem
Graphing Problem - Can't graph piece wise function -SOLVED - Messaggi
#1 Pubblicato: 03/10/2017 23:38:03
dlyon
dlyon
0 apprezzamenti in 5 post.
I've tried many ways from examples I have found on the internet, but I just can't get the graph to plot. What am I doing wrong?
Any help would be greatly appreciated.
[b]Foot note:
The problems are solved. The main problem was units; units must be correct through out. When using constants be sure the value also has units attached (1.5 m, not 1.5, for example). The second was that for the extended graph plugin there seems to be a limit on the levels of conditional functions you can call. I ended writing the function as a one line which worked:
Citazione
m(x)={((x≥0m)&(x
#2 Pubblicato: 04/10/2017 06:08:56
csb531
csb531
0 apprezzamenti in 24 post.
Hello Dave,
maybe a simple scaling problem? Your results are of magnitude 8 N, your plot is in [kN].
Try scaling the plot area with [Ctrl]+scroll wheel or [Shift]+ scroll wheel.
Hope this helps...
Regards, csb.
#3 Pubblicato: 04/10/2017 07:51:33
Dave, please attach the work sheet.
#4 Pubblicato: 04/10/2017 11:19:15
dlyon
dlyon
Here Jean, thanks for looking
DaveMAST.sm (1,43 MiB) scaricato 1303 volta(e).
#5 Pubblicato: 04/10/2017 12:07:09
Gruppo: Moderator
Input units are needed... in the standard 2D plot, just use p(x*'m) / V(x*'m)
#6 Pubblicato: 04/10/2017 12:18:53
1. The X_Y plot does not take conditional
2. Quick plot does not take units [there is way to trick]
3. units removed from the two conditional ... plots !!!
Cheers... Jean
MAST.sm (1,43 MiB) scaricato 1294 volta(e).
#7 Pubblicato: 04/10/2017 13:31:53
dlyon
dlyon
Yahoo! Thanks Jean! I understand the problem!
Dave
