For loop - 1 seat every 30 people
For loop - 1 seat every 30 people - Messaggi
#1 Pubblicato: 11/10/2021 16:34:23
talpacolore
talpacolore
0 apprezzamenti in 4 post.
Hi to everyone, I'm a new user of S-math.
I'm a newbie to programming.
Today I had to make a calculation to size the number of seats in a waiting room according to the total number of people.
The number of seats must be 1 for every 30 people.
I tried to make the calculation automatic via S-math, but I was unable. I thought the for loop might help me, but I don't know how. Can someone help me?
#2 Pubblicato: 12/10/2021 04:25:23
Gruppo: Moderator
You should start from the problem itself... How would you solve it in mathematical or pseudocode form?
#3 Pubblicato: 12/10/2021 09:57:04
That's my understanding of your project.
Jean.
#4 Pubblicato: 12/10/2021 13:19:00
talpacolore
talpacolore
Hi I try to explain better what I want to calculate.
I would like to set up a for loop that allows me to do the same calculations as the if loop in the figure.
for example
if n.pers < 10 ---> n.s = 1
if n.pers > 10 & n.pers < 30 ---> n.s = 2
if n.pers > 30 & n.pers < 60 ---> n.s = 3
if n.pers > 60 & n.pers < 90 ---> n.s = 4
and so on
I don't know how if it's possible set up this cycle, anyway thanks.
#5 Pubblicato: 12/10/2021 13:57:13
Gruppo: Moderator
for example
and so on
You don't need an iteration.
Ceil() and cases() shall work for you.
Davide Carpi 12/10/2021 16:15:00
#6 Pubblicato: 12/10/2021 14:29:11
talpacolore
talpacolore
Hi
I'm probably doing something wrong because, for exemple, with 40 or 70 it doesn't work.
#7 Pubblicato: 12/10/2021 14:38:28
Gruppo: Moderator
Hi
Probably, please use the file below.
seats.sm (2,79 KiB) scaricato 1228 volta(e).
#8 Pubblicato: 12/10/2021 14:50:02
127 apprezzamenti in 342 post.
The suggestion of Overlord is correct. You can also define a function and make different corresponding values ​​calculate (using the Vectorize function)
number_seat.sm (6,94 KiB) scaricato 1287 volta(e).
#9 Pubblicato: 12/10/2021 15:11:23
talpacolore
talpacolore
Thank to all. you are great!
I used an old version. Now work correctly in my pc, too.
#10 Pubblicato: 12/10/2021 15:41:15
Page8 Social.sm (16,79 KiB) scaricato 1496 volta(e).
#11 Pubblicato: 12/10/2021 17:42:31
Gruppo: Moderator
Not related with OP's question.
#12 Pubblicato: 12/10/2021 20:25:44
You can elongate at will:
1. collect the last condition from RHS
2. double coma
