1 pagine (10 elementi)
rank - Messaggi
Hallo zusammen,
DimEigenraum: (n-rank(A-λ*E))=1@#
should be 2
some steps of elementary row additions later
is 2
https://de.smath.com/cloud/sheet/vooDFR4FbP
any idea whats wrong?
should be 2
is 2
This link doesn't works, be sure to use the share button link (on the right of the save button), because the address bar link is restricted to the author only.
Upps, sorry
Made a link
https://de.smath.com/cloud/worksheet/3BgYDE7e,
Maxima pure
(%i6) A: matrix([1,1,1,-1,0],[0,1,0,0,1],[0,0,0,1,0],[0,0,-1,2,1],[0,0,0,0,1])$
(%i7) A-1*ident(5)$
(%i5) rank(A-1*ident(5));
(%o5) 3
but
Maxima(rank(A-1*identity(5)))=4
or
Made a link
Maxima pure
(%i7) A-1*ident(5)$
(%o5) 3
but
or
The referenced sheet seems to use Maxima(). This doesn't work, as third party plug-ins aren't available in the cloud version.
It is better to attach such files here.
rank(M) ... matrix rank is Smath built-in.
Here is a most precious application.
Matrix PseudoInverse.sm (111,21 KiB) scaricato 1232 volta(e).
Wroterank(M) ... matrix rank is Smath built-in.
and in how far do your example explain the incorrect calculation
WroteThe referenced sheet seems to use Maxima(). This doesn't work, as third party plug-ins aren't available in the cloud version.
the Maxima part calculate the single eigenvalue which is set manually in cloud version
![SMath Studio 0.99.6884 - [JordanMatrix5x5-5fachEW-HV.1.2.Stufe.sm_]_2020-04-19_19-07-08.jpg](/it-IT/files/Download/SRDYrq/SMath-Studio-0.99.6884---[JordanMatrix5x5-5fachEW-HV.1.2.Stufe.sm_]_2020-04-19_19-07-08.jpg)
JordanMatrix5x5-5fachEW-HV.1.2.Stufe .sm (47,19 KiB) scaricato 1190 volta(e).
Wroteand in how far do your example explain the incorrect calculation
Just advanced maths above the classroom.
Your example replies bug from incorrectly threaded input.
As given, your [5*5] matrix has no mathematical meaning.
Page1 rank.sm (11,74 KiB) scaricato 1361 volta(e).
sergio 20/04/2020 12:15:00
... Rank(V)
Given a set of data values, the rank of each value is the position
at which that value appears in a sorted list of the data.
When values repeat, the rank is an average of the indices where
the value occurs after sorting.
