ODEsolve HIRES
ODEsolve HIRES - ODEsolve HIRES - Messaggi
#1 Pubblicato: 09/10/2016 11:41:32
A gorgeous piece of work from Smath built-in solver.
Enjoy, Jean
ODE HIRES.sm (48,51 KiB) scaricato 1634 volta(e).
Radovan Omorjan 09/10/2016 12:18:00, Andrey Ivashov 09/10/2016 17:01:00
#2 Pubblicato: 09/10/2016 12:30:18
Gruppo: Moderator
Thank you Jean for this example,
You can also try the solvers from Matlab C++ Math Library and from ODE Solvers plugins (stiff solvers) as well.
#3 Pubblicato: 10/10/2016 00:18:42
I'm with you Radovan,
HIRES solves equally well from both solvers libraries [dn_ & mwode]
Example 2 [from Yuk]: NONE solve except Smath built-in rkfixed,
at a very specific number of points which is different than Mathcad.
Example 3 [from Valery] solves ONLY Matlab "mwode..."
All that is documented in the attached. All that said, you may wonder
how it works in real life. From educated practice, the Chemist can
pose the solver frame work ... from there and experimental results,
some solvers will optimise the "Frame work model" [typical of medical].
On that optimise option, Mathcad 11 is fully capable. Several examples
were exchanged in the Mathsoft collaboratory.
I will be back on that... cheers, Jean
ODE HIRES.sm (79,49 KiB) scaricato 1532 volta(e).
#4 Pubblicato: 10/10/2016 01:32:35
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Jean, you can use RelTol and AbsTol constants with the solvers.
EDIT:
All ode solvers realized as external functions. They are located in the plugins. rkfixed too (ODE Solvers plugin). So, there are no any built-in ode solvers.
