How to put signs like paranthesis to collect the data in one place
How to put signs like paranthesis to collect the data in one place - system, sys(...) - Messaggi
#1 Pubblicato: 07/06/2016 08:44:41
farzadtb
farzadtb
0 apprezzamenti in 10 post.
Hi All
I dont know how to do like this link , to gather my data neatly in one paranthesis , I dont know it's name
http://en.smath.info/forum/yaf_postst7446_About-Units.aspx
#2 Pubblicato: 07/06/2016 10:18:50
Gruppo: Moderator
It's a system... Type sys and then press the TAB key; it is available even as last element in the "Functions" toolbox (right side of the canvas); using the "argument separator" key (that commonly is comma or semicolon, depending on your settings), you can add more lines.
#3 Pubblicato: 07/06/2016 10:27:47
farzadtb
farzadtb
Thank you very much , but I can not add more lines correctly, it seems that separator is not active
#4 Pubblicato: 07/06/2016 10:39:04
Gruppo: Moderator
I cannot check right now but I've not noticed issues recently. Go to tools > options and check if you are using the right character.
#5 Pubblicato: 07/06/2016 13:16:37
In a single column vector, you can add place holder(s): type coma on the last
entered value. If you have too many : press Backspace. If you have constructed
an array [matrix], you need some tool to add/remove cols/rows. These tools are
available in the attached "Matrix Treasury".
Cheers, Jean
Utilities Matrix Treasury Copy.sm (285,74 KiB) scaricato 1261 volta(e).
This treasury was made in Smath older OFFicial release [April 2014] 5346.
#6 Pubblicato: 07/06/2016 16:48:15
farzadtb
farzadtb
Ok here is the image, attention that in the below equations , I gave up making a system, I have just written down the 4 last equations ,only for the input data it worked well
#7 Pubblicato: 07/06/2016 19:27:11
Mike Kaganski
Mike Kaganski
184 apprezzamenti in 434 post.
Please notice that you cannot have results individually next to each subexpression in system: the system is one global expression that contains others, and only top-level expression's result may be displayed.
Also notice, that for systems (or matrices as well) of heterogenous elements, you cannot specify units, and even simple units (like Pa) will be displayed as their internal representation of base units of length, time, mass etc.
For homogenous structures, you may specify the common unit in the rightmost unit placeholder, as usual
One more thing: when posting screenshots displaying a question, it's generally a good idea to accompany it with an .sm file, so that others could avoid re-typing everything trying to reproduce.
С уважением, Михаил Каганский
#8 Pubblicato: 07/06/2016 21:16:26
What else to complete a project ?
#9 Pubblicato: 08/06/2016 08:32:46
farzadtb
farzadtb
Thank you so much for your perfect answers
#10 Pubblicato: 08/06/2016 09:45:47
Welcome ... two typos expe"r"imental, cros"s"
