Unit proof int()
Unit proof int() - BTS issue SS-85 - Messaggi
#1 Pubblicato: 11/08/2013 16:33:55
Gruppo: Moderator
I propose to modify the built-in function int(4) such that it can handle integration variables with units. It is easy to build a corresponding function thanks to Davide's UoM() and for maple(int(4) this already works.
[MATH lang=eng]Int(f#,x#,a#,b#):line(u#:UoM(b#-a#),sf#:num2str(f#),sx#:num2str(x#),sxu#:num2str(x#*u#),ft#:str2num(strrep(sf#,sx#,sxu#)),u#*int(ft#,x#,a#/u#,b#/u#),6,1)[/MATH]
See attached sheet for examples.
Edit: Shifted to bug tracking system
Section math integration units.sm (19,47 KiB) scaricato 1427 volta(e).
Вячеслав Мезенцев 11/08/2013 18:48:00, ioan92 12/08/2013 03:48:00, Davide Carpi 23/08/2013 07:55:00
#2 Pubblicato: 20/09/2013 11:46:55
Gruppo: Moderator
The request is resolved by the Maxima Plugin.
Section math integration units.sm (22,95 KiB) scaricato 1516 volta(e).
Radovan Omorjan 20/09/2013 14:50:00
