MS Chart Region
MS Chart Region - 🚧 Extends SMath Studio with a Microsoft Chart Region - Messaggi
#1 Pubblicato: 21/06/2019 11:42:51
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
MS Chart
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
File non trovato. File non trovato.
Implementation started
This component has many types of graphs. I hope that I can make them comfortable to use.
I think that this component will not work in Linux.
8 utenti hanno apprezzato questo post
Alvaro 21/06/2019 14:34:00, Davide Carpi 22/06/2019 17:03:00, frapuano 21/06/2019 17:16:00, Arie 24/06/2019 11:29:00, NDTM Amarasekera 21/06/2019 23:10:00, Andrey Ivashov 22/06/2019 12:47:00, Radovan Omorjan 21/06/2019 13:19:00, sergio 21/06/2019 11:55:00
#2 Pubblicato: 22/06/2019 10:43:41
Thanks Viacheslav.
Something unusual: can't reply "Quote" on this one.
Would be interesting the plugin could be added SS 6179 ?
#3 Pubblicato: 22/06/2019 13:01:54
Gruppo: Moderator
The API has changed significantly in recent versions of the program. I think it makes sense to create a new plugin using the new changes in API.
I will try to add support for most of the chart types.
4 utenti hanno apprezzato questo post
frapuano 22/06/2019 13:55:00, Radovan Omorjan 22/06/2019 13:35:00, Davide Carpi 22/06/2019 17:03:00, Arie 24/06/2019 11:29:00
#4 Pubblicato: 25/06/2019 15:25:53
Hi uni. Thanks for the new plugin. Two things. One, the link in the "credits" it's broken. This is, not the text for the sources, but the link in the html. Also, in the meantime, can you provide just one or two very simple examples? I don't know how to insert the ms chart.
ALvaro.
#5 Pubblicato: 25/06/2019 16:19:52
Gruppo: Moderator
Updated.
Changes:
- serialization added;
- some default chart properties changed.
How to insert:
There is still a lot of work to improve component stability.
Alvaro 25/06/2019 17:09:00, frapuano 26/06/2019 01:24:00
