Plot SMath 0.91 vs. SMath 0.92
Plot SMath 0.91 vs. SMath 0.92 - Messaggi
#1 Pubblicato: 06/03/2012 10:18:30
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
Hi Andrey,
I test the new version (0.93) and found the same problem that version 0.92. This is the result from same file.
Plotting in 0.91:
Plotting in 0.93:
Oscar
#2 Pubblicato: 06/03/2012 10:31:34
Gruppo: Moderator
Hello Oscar,
Here is the same file I reported it was wrong in v0.92 (the same post when you reported your problem).
It seems to me quite right in v0.93. It must have been something else regarding your problem. Can not see what's wrong at the moment.
radovan
#3 Pubblicato: 06/03/2012 12:06:16
Gruppo: Super Administrator
This was fixed in 0.93 (the reason was a bug regarding constants).
Regards.
#4 Pubblicato: 06/03/2012 16:41:02
Oscar Campo
Oscar Campo
Gruppo: Moderator
Regards.
Sorry, but in my post I show that problem persist in 0.93. It is not fixed.
Oscar
#5 Pubblicato: 06/03/2012 17:53:15
Gruppo: Moderator
Regards.
Oscar
same results of oscampo with Smath 0.93, win7
http://www.mediafire.com/?6uf36mq2xc0ykvi
#6 Pubblicato: 06/03/2012 18:15:18
Ok. I'll check it. Thank you.
Regards.
#7 Pubblicato: 07/03/2012 03:53:51
Gruppo: Moderator
I think I found the problem. It seems it is again regarding Optimization
Look at the first picture please:
The blue line is a function of x, as in the Oscar's example. The red line is plotting two column vectors. I used the larger step just to see the difference. Either way the q1(x) has been calculated wrong.
Here is another picture with Numerical optimization applied on both q1(x) and for loop.
This time q1(x) has been calculated correctly. Unfortunatelly, the function plot is still wrong and I do not know how to change this.
Actually there is a way by using eval()
But another problem appeared. I can not see why the error in the third plot. Separate plot are possible but not the joined plot? Could someone try to reproduce or to explain this, please. Here is the file Oscarplot.sm
#8 Pubblicato: 19/03/2012 17:58:03
Fixed.
Regards.
Oscar Campo 19/03/2012 22:22:00, Radovan Omorjan 20/03/2012 03:33:00
