Problem with integral
Problem with integral - Messaggi
#1 Pubblicato: 01/04/2019 13:53:58
dzon_doe
dzon_doe
0 apprezzamenti in 2 post.
I have a problem with the integral. Please find the exemplary attached to this post. I have defined several variables and their units. In my opinion, everything is OK but SMath does not solve it when the temperature is defined as a vector T, or solve only the first integral if temperatures are defined separately (as T.1 and T.2). Can you explain to me why SMath cannot solve this integral?
int_issue.sm (8,04 KiB) scaricato 1182 volta(e).
Best regards,
dzon_doe
#2 Pubblicato: 01/04/2019 15:32:36
Sure it integrates an integrand and more.
int_issue.sm (11,65 KiB) scaricato 1230 volta(e).
#3 Pubblicato: 01/04/2019 16:02:09
dzon_doe
dzon_doe
To be honest, your explanation is not clear for me but I noticed that you removed all units. And in my sheet, it also works. Does the units the source of the problem?
Best regards,
dzon_doe
#4 Pubblicato: 01/04/2019 17:22:29
You first wrote:
Can you explain to me why SMath cannot solve this integral ?
Now you reply: And in my sheet it also works.
Maths are unitless, so I reject carrying units,
there are very many instances not supporting units.
Units were discussed ad nauseum in Mathsoft forum,
in > 125000 exchanges: not a single work sheet in units.
#5 Pubblicato: 01/04/2019 18:31:52
Hi. Try this:
#6 Pubblicato: 01/04/2019 20:22:41
Gruppo: Moderator
Maxima can handle integrals with units. Yet the restriction applies that the integration variable must be undefined.
int_issue_Kr_units.sm (10,14 KiB) scaricato 1205 volta(e).
#7 Pubblicato: 01/04/2019 22:49:00
Native Smath does it in much greater elegance.
int_issue [Transit Method].sm (9,39 KiB) scaricato 984 volta(e).
#8 Pubblicato: 02/04/2019 09:14:40
Refreshed version managed from annoying units
Integral 0000000 Transit-Units.sm (23,78 KiB) scaricato 1214 volta(e).
