Different Results of Integration in 7219 & 7250 (Gamma Function) - Messaggi
But, the attached SS File yields an error due to different result of
integration in 7250 compared to result in 7219.
SPI_Calc_Plain.sm (111,38 KiB) scaricato 1381 volta(e).
File non trovato. File non trovato.
Fixed in 7251 (will be available very soon).
UPDATE: Released here: https://en.smath.com/forum/yaf_postst17461_Beta--SMath-Studio-0-99-7251--08-November-2019.aspx
Best regards, Andrey Ivashov.
Still I get errors in SS 7251.
I will come back soon.
Sorry for the inconvenience.
and Eqns 1, 2 and 3.)
SPI_Calc_Plain.sm (125,02 KiB) scaricato 1394 volta(e).
Rainfal_Data.xlsx (486,32 KiB) scaricato 975 volta(e).
WroteIntegration results of Mathcad attached (using first 10 elements of X
What I understand from your previous reports is that
the Simpson integrator is kaput again in latest SS version.
What more is kaput ? SS 6179 does not open your attachment.
In the mean time, can you doctor rkfixed your document ?
NDTMA.sm (54,8 KiB) scaricato 1312 volta(e).
WroteIn the mean time, can you doctor rkfixed your document ?
Thank you. I will try my best ASAP.
In the mean time following files are attached.
Test_Gamma_7251.sm (35,67 KiB) scaricato 1350 volta(e).
Test_Gamma_7251.pdf (192,13 KiB) scaricato 848 volta(e).
WroteThank you. I will try my best ASAP.
Here is doctored sanity MCD.
Don't forget Smath Gamma(x) is only globally 4 decimals,
immaterial in your CDF integration. If you need to check
the peak location of PDF, we have the Golden ratio algo.
Enjoy ... Jean.
NDTMA Test Gamma.sm (45,33 KiB) scaricato 1362 volta(e).
NDTMA Test Gamma.sm (22,63 KiB) scaricato 1343 volta(e).
Golden Ratio jmG.sm (35,96 KiB) scaricato 1344 volta(e).
in 7251 were not compatible with 7219.
I wish to add that similar working in 7219 reasonably tally with MCD and EXCEL,
while 7251 is not so. I believe that may be the reason why I got errors using
SS ICDF.normal function in SPI calculations (some CDF values>1 ??).
Anyway, I am attaching the following files and images for further examination please.
Many thanks to all for their comments.
Fimal Gamma Results.zip (1,14 MiB) scaricato 439 volta(e).
Test_Gamma_7251.sm (103,8 KiB) scaricato 1372 volta(e).
But, very often, as practicing Engineers, we are inclined to use built-in
functions as much as possible in our day to day work in the design office.
The SPI calculation was such an effort I came across.
WroteSincerely, I was trying to show that results of Gamma Function PDF and CDF
As you say ... hard to doctor this patient.
Your download opened by default on my 6179 carries the bug.
Could it be the vectorize operator is the cause ?
If so: that would be quite a bug !
Test_Gamma_7251 [6179].sm (22,54 KiB) scaricato 1266 volta(e).
WroteAs you say ... hard to doctor this patient.
It worked! Thanks, but how?
Test Gamma [2] 7251 [6179].sm (25,75 KiB) scaricato 1218 volta(e).
![Test Gamma [2] 7251 [6179].png](/it-IT/files/Download/HZz3Yc/Test-Gamma-[2]-7251-[6179].png)
Hi Nugegodage. I absolutely agree. Actually, I post for try to find where the bug is.
I include gamma too, because I think that, like happen in matlab and maple, plugins can be written in native smath code, not in c++. Maybe in this case, gamma and other special functions are not the best example for do that, but this is only meanwhile they are in plugins, not in smath native functions.
In my point of view, plugins are good for graphics, some objects (like formatted cells, writer regions), communication with external programs (maple, maxima) and some other things.
WroteCould it be the vectorize operator is the cause ?
I have edited part of my original "SPI_Calc_Plain.sm" worksheet, and it
is evident the bug due to the vectorize operator.
Will come back soon with the edited version.
Thank you very much.
TEST-SPI_Calc_Plain.sm (52,55 KiB) scaricato 1324 volta(e).
WroteIt worked! Thanks, but how?
Answer is from observation(sss..)
My work sheet is clean and thus opened/calculated your 7251.
Your 7251 is corrupted and my 6179 executed the vectorize bug.
Mathematica has the expression shadow in context.
Read this: 6179 does not come with ZedGraph, one day some collab
posted a ZedGraph, 6179 did open and now my 6179 has ZedGraph.
SS 6346 had two versions: the official and un-official.
The un-official did lot more than the published version.
Detail about Gamma(x)like erf(x): under the integration operator,
they both need be vectorized. Maybe, the fact that I renamed/recast
it may have the virtue of doctoring. Though your Gamma(x) does
not play apparent role in the integration, it is still there as
a reluctant item to evaluate.
Now, if you recast your Gamma(x) Γ(x) in your original 7251
what happens bug/no_bug ? Like the English say: square the corner.
WroteHi Nugegodage. I absolutely agree
Thanks Alvaro,
Never Give up. Great things take time.
