num2str bug with matrices
num2str bug with matrices - num2str error with certain matrices - Messaggi
#1 Pubblicato: 07/01/2013 19:13:47
sublim21
sublim21
3 apprezzamenti in 36 post.
Hey all,
I was trying to write a variable type detection script, so i can know if a variable is a number, matrix, string etc.
Everything was working until i tried num2str matrices.
Most work:
num2str(mat("b",1,1)) =
However, if an entry in the matrix contains a space or other special character, an error occurs.
num2str(mat(" b",1,1)) =
**EDIT UPDATE - The original post stated that only leading spaces would result in an error. This is incorrect. Any space in the matrix entry results in an error.
Any help in this regard is greatly appreciated.
-Pete
#2 Pubblicato: 07/01/2013 21:16:16
Gruppo: Moderator
Hey all,
Most work:
However, if the leading character in the text is a space or other special character, an error occurs.
There is no error if the text ends in a space, or other special character.
num2str(mat("b ",1,1)) =
-Pete
I can confirm (it's a known bug)
regards,
w3b5urf3r
