Square root/power of and matrices
Square root/power of and matrices - Messaggi
#1 Pubblicato: 07/04/2017 04:55:17
mykologen
mykologen
1 apprezzamenti in 5 post.
Hi there!
I am having an issue with a definition witch gives following error: "Cannot calculate"
Please se section under ERROR in attached file. Can't figure out why it wont work... suggestions?
Thanks!
3020-3050.sm (21,41 KiB) scaricato 1245 volta(e).
#2 Pubblicato: 07/04/2017 05:20:07
Gruppo: Moderator
Just put the vectorize wherever you find the error. There will be no errors anymore.
mykologen 07/04/2017 06:24:00
#3 Pubblicato: 07/04/2017 06:14:23
mykologen
mykologen
That does not seem to work, updated my file with my tries... 3020-3050.sm (24,91 KiB) scaricato 1186 volta(e).
#4 Pubblicato: 07/04/2017 06:15:44
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
The revised worksheet attached pl.
3020-3050_R1.sm (22,62 KiB) scaricato 1325 volta(e).
mykologen 07/04/2017 06:24:00, Radovan Omorjan 07/04/2017 06:52:00
#5 Pubblicato: 07/04/2017 06:23:58
mykologen
mykologen
Thanks a lot!
#6 Pubblicato: 07/04/2017 06:54:41
Gruppo: Moderator
Thanks a lot!
I should have attached the corrected file like ndtma did, sorry.
mykologen 07/04/2017 06:56:00, NDTM Amarasekera 07/04/2017 08:54:00
#7 Pubblicato: 07/04/2017 08:39:07
Thanks a lot!
In your application, my preference goes for "global vectorize".
It makes easier to manipulate equations.
#8 Pubblicato: 08/04/2017 09:00:54
NDTM Amarasekera
NDTM Amarasekera
Thanks a lot!
Pl look at this.
3020-3050_R2.sm (30,42 KiB) scaricato 1256 volta(e).
mykologen 10/04/2017 06:47:00
#9 Pubblicato: 09/04/2017 23:10:35
You are right: this project is not a case for "vectorize".
It makes much easier to read and pass QA [Quality assurance].
3020-3050_R2.sm (24,81 KiB) scaricato 1221 volta(e).
