1 pagine (8 elementi)
Reset/Remove Variable - Variable delete - Messaggi
Dear members,
in often times I need the variable x . Then in next time I make
in Example a differential of Function, and x is rember of value or defition.
In mathCad I remove a variable with x:=x.
What can I do in SMath ?
So many thanks for help.
Topsi
Topsi
WroteDear members,
Topsi
Hi Topsi,
AFAIK the only way it's to use a 2nd empty variable.
f.e.
[LIVE width=170 height=157]http://smath.info/live/?file=4019[/LIVE]
regards,
w3b5urf3r
Hello w3burf3r,
thanks for your help, but I can't type the symbol # in place holder.
A free new variable, that will be good. But in the teaching I will
have always the x - variable.
Have you a little helb for this new question.
Thanks for help
Topsi
Thanks for help
Topsi
Hi
I know, it's not a wonderful solution... I've already attempted to create a Clear() function inside a plugin - nothing to do
You can post a Feature request in the forum, IMHO would be an useful feature
As for the # character, you must write at least one letter and then you can write the # before the first character (I don't know if this is a bug or a feature).
regards,
w3b5urf3r
regards,
w3b5urf3r
An easy way to remove a variable is use another variable but undefined:
So, you must the "clean" variable undefined.
Oscar
Oscar
WroteHi,
Sorry, does not work here. Clean removal would make X appear as result in the mapUnknown function from the NonLinearSolvers plugin.(see here).
Best regards, Martin Kraska
All helpers,
many thanks,
sorry, but my problem ist not lost. That is very trouble of SMath that I can't
remove a variable. See what I meen:
x:=3
x=3
x:=clean
x=
f(x):=x³
d
- f(x)=3 clean²
dx
that is very bad.
I think in the next version it will be.
So if anywhere help me than I give thanks bevor.
Topsi
many thanks,
x:=3
x=3
x:=clean
x=
f(x):=x³
d
- f(x)=3 clean²
dx
that is very bad.
Topsi
I see...
So I join the request for a clear() function: http://en.smath.info/forum/yaf_postst1576_clear---function.aspx
