FindRoot Error
FindRoot Error - Help Needed for FindRoot Function - Messaggi
#1 Pubblicato: 10/07/2017 15:54:49
MSL
MSL
1 apprezzamenti in 22 post.
Hi
I need a help for "FindRoot" function.(See attached file)
Also I got an error sample file(Inst_Colebrook_pipe_data.sm) which was downloaded from this forum.
Please, guide me to solve this error.
Novice
FindRoot_test_0.sm (40,44 KiB) scaricato 1290 volta(e).
#2 Pubblicato: 11/07/2017 19:19:08
Gruppo: Moderator
Hello [userlink]Novice[/userlink]
An important thing is that Q1 must be undefined while you define the system of equations - and as for now even when you call FindRoot; there is a buil-in function Clear(...) for this.
Secondly as for now when there are numerical functions involved in the evaluation of the unknowns this plugin has issues (in this case the issue is in if(f(Q1), that can be replaced by cases(...), however the algorithm then fails to solve for the given initial guess);
FindRoot_test_0.sm (38,94 KiB) scaricato 1240 volta(e).
I'm working to improve both these things.
Radovan Omorjan 12/07/2017 02:01:00
#3 Pubblicato: 12/07/2017 10:09:15
You MUST draw the diagram first !
Get inspired from NDTMA Collab [Colebrook Node].
Comments:
1. The "GivenFind" solver does not necessarily solves.
I have recollection solving for 22 variables in Mathcad 11.
It was necessary to constrain some variables, and this was
possible from some existing models, in fact: just refining
within the "solvability" of the system.
2. You have 7 'Q' indexed: that's not viable.
Instead: Q1, @2, Q3, ... Q7
3. Please rework the project to ease reading/understanding.
Inst_Colebrook MOODY.sm (21,92 KiB) scaricato 1284 volta(e).
Inst_Colebrook Pipe Data.sm (59,97 KiB) scaricato 1297 volta(e).
Solve Given_Find [UN Frobenius C1, C2].sm (71,34 KiB) scaricato 1144 volta(e).
FindRoot_test_0 Revisit.sm (41,94 KiB) scaricato 1286 volta(e).
Inst_Colebrook Pipe Data [Solve Node Flow].sm (149,29 KiB) scaricato 1116 volta(e).
Inst_Colebrook.sm (191,95 KiB) scaricato 1307 volta(e).
Inst_Colebrook.sm (191,95 KiB) scaricato 1281 volta(e).
#4 Pubblicato: 15/07/2017 07:56:58
MSL
MSL
Dear Jean,
Thank you very much for your advice and examples
It is helpful to me.
Thank you!
MS
