Maxima Plugin problem
Maxima Plugin problem - functions doesn't work properly - Messaggi
#1 Pubblicato: 23/12/2021 17:49:19
Francois Tremblay
Francois Tremblay
0 apprezzamenti in 1 post.
Hi, I ran into an issue trying to use Solve() function with Maxima plugin.
I installed the last version of plugin (5.45.1)
and even the refence book seems to not work properly:
Click to enlarge
although, when I remove the L:= it does solve again.
Click to enlarge
how could I resolve this issue?
regards,
#2 Pubblicato: 23/12/2021 22:05:31
regards,
Hi. Think of Solve's non-evaluation problem as something similar to what you get with Hold in Mathematica or with 'x' in Maple. I do not know if it is a change in the behavior of the plugin that is here to stay, or an unwanted effect due to an update, but what you can do is not define with := and ask in the same line for the symbolic result, but first define L := Solve (...) and then symbolically evaluate L ->
this means, SMath needs another step to proceed to evaluate the expression in Solve.
#3 Pubblicato: 24/12/2021 09:35:29
From native Smath 6179.
#4 Pubblicato: 24/12/2021 12:37:06
Gruppo: Moderator
Not related with OP's question.
Your reply doesn't have the answer also.
