Angles trygonometry value in solutions of the system of equations
Angles trygonometry value in solutions of the system of equations - Messaggi
#1 Pubblicato: 09/09/2021 04:25:42
Mateusz
Mateusz
0 apprezzamenti in 8 post.
How to turn of the decimal values in trygonometry angles value? I got sth lik this for solution of system of equations:
The file with example: example_v1.sm (8 KiB) scaricato 1186 volta(e).
A.
#2 Pubblicato: 09/09/2021 06:44:19
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
You can use the function al_nlegsolve with any initial
assumptions (because the equations are linear)
al_nlegsolve.sm (11,18 KiB) scaricato 1187 volta(e).
#3 Pubblicato: 09/09/2021 09:52:40
How to turn of the decimal values in trigonometry angles value ?
By default, trig are in decimal radian in all CAS.
Recast your solutions, fill-in the unit place holder.
#4 Pubblicato: 09/09/2021 23:20:45
Hi. You also can use Maxima commands, in this case ev():
#5 Pubblicato: 10/09/2021 05:37:18
Gruppo: Moderator
example_v1.sm (13,63 KiB) scaricato 1205 volta(e).
sergio 10/09/2021 06:11:00
#6 Pubblicato: 10/09/2021 13:02:39
Hi Martin. I use Maxima's ev() because SMath's Assign() only works with the variable names, instead others, like xo, yo, and SMath's at() doesn't works for the symbolic evaluation, as shown this picture:
example_v1.sm (15,95 KiB) scaricato 1183 volta(e).
This is a workaround for use only SMath native functions or plugins, without any explicit Maxima function:
example_v2.sm (15,16 KiB) scaricato 1254 volta(e).
sergio 10/09/2021 13:43:00
