1 pagine (16 elementi)
Draw Bar Graph in XY Plot or ZedGraph - Messaggi
As far as I know there are no bar graphs in SMath. At least, there is no easy way to obtain them.
I wish I was wrong about it.
Just in case, might worth the effort to try with the modeller region
True
WroteAs far as I know there are no bar graphs in SMath.
True
Somehow Davide, you crossed my mind when I posted the answer
It seems I was right
Wish you the best of luck,
Thank you very much Davide and Radovan for your clarifications.
I know nothing about "Zedgraph".
I can se Davide had a "cat in the hat".
Stem plot does same/different in no time
except for the red 0 rain [<20 sec]
Cheers, Jean
Forum Rainfall.sm (87,7 KiB) scaricato 1337 volta(e).
Cheers, Jean
This scrap proposal makes me happy for some
distinctive small project. Manual but convenient
for small projects. For larger size and unicolor
the project needs be constructed around a counter.
4 utenti hanno apprezzato questo post
frapuano 08/11/2016 05:02:00, Radovan Omorjan 08/11/2016 03:42:00, Davide Carpi 08/11/2016 06:03:00, NDTM Amarasekera 08/11/2016 06:40:00
Thank you for the examples.
I will try my best to use them to suit my problem.
Many thanks to Uni, for the simple example.
I was expecting a response from you also.
In the Viacheslav proposal, you don't see bar not plotting equally wide.
Because the bars are so wide ! In the real project I proposed, the bars
are much thiner for dense project. Thus there will always be at least
"one" bar looking thiner because of the plot pixel impossible to match
perfectly along the stretching of the plot.
Cheers, Jean
Cheers, Jean
WroteSimple example
I used method proposed by Uni to plot Bar Graph to show rainfall in ZedGraph as shown (in reverse order).
File non trovato. File non trovato.
Thanks for the "Zed Graph" snippet. I don't have this plugin
whereas I will stay Smath 5346, and don't intend to upgrade.
The attached document is for publising projects.
Cheers, Jean
2D Bar Plot Custom.sm (35,01 KiB) scaricato 1310 volta(e).
Cheers, Jean
![2016-11-07 19_46_36-SMath Studio - [Page1_].png](/it-IT/files/Download/3nBkXT/2016-11-07-19_46_36-SMath-Studio---[Page1_].png)
![2016-11-07 19_58_13-SMath Studio - [Page1_].png](/it-IT/files/Download/xpYdNE/2016-11-07-19_58_13-SMath-Studio---[Page1_].png)
