Maxima Plot path error
Maxima Plot path error - Messaggi
#1 Pubblicato: 21/03/2019 14:41:14
Topsi
Topsi
0 apprezzamenti in 8 post.
Hello SMath user,
Plotting with Maxia doesn't work. Insert /Maxima/ 2D-3D plot
results in an error message..: Cannot find the path (see appendix).
In the German language the character o with arc does not exist.
Here the path name contains the a with points ä . Can I use the
Set path Are there other possibilities? Want to use Maxima plot
not with 3DPlot.
Thank you
topsi
#2 Pubblicato: 21/03/2019 18:08:11
Gruppo: Moderator
Normally the plugin should be unicode-proof. It uses SBCL. Does the plot work in wxmaxima?
