1 pagine (8 elementi)
Function from plot - Messaggi
WroteHow can I get a function from this plot ?
1. Probably from the expensive digitizer suggested by Richard [Mathsoft Collaboratory]
2. Piecewise from Tracer.
3. Try Mathsoft digitizer.
4. Smath difficult
At this point from the collected data set, fit a model function.
Valery Ochkov 06/06/2023 10:24:00
Greetings,
That is a straight line on a semi-log graph; you can reference this handout: https://inside.mines.edu/~epoeter/_GW/LAB/EquationsOfStraightLinesOnDifferentTypesGraphPaper.pdf
Per this handout, your equation should be where:
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
WroteHow can I get a function from this plot? 🖼
y = b + m*log(x)
- m = difference in y over one log cycle of x
- b = y value corresponding to x=1
Hi. You can try this post Approximation of a functional curve in a digital image or this other one: Embedding images into a plot
Hello Valery,
some Smath digitizing utilities
Cheers, Jean.
Digitize Tracer 15.sm (28,83 KiB) scaricato 1389 volta(e).
Digitize OVNI Copy.sm (69,15 KiB) scaricato 1373 volta(e).
Digitize Contour Isocurve Himmelblau Copy.sm (106,67 KiB) scaricato 1436 volta(e).
Digitize Curve.sm (295,86 KiB) scaricato 1363 volta(e).
Digitize Contour.sm (829,05 KiB) scaricato 1448 volta(e).
Digitize Clean_Strip_Smooth.sm (1,76 MiB) scaricato 1485 volta(e).
... this Himmelblau has resident Gray matrix.
Digitize Contour Isocurve Himmelblau Copy.sm (107,19 KiB) scaricato 1438 volta(e).
Valery Ochkov 07/06/2023 01:02:00
Hi. Hope this helps.
Modeling a functional curve in a digital image.pdf (860,39 KiB) scaricato 917 volta(e).
Modeling a functional curve in a digital image.sm (1 MiB) scaricato 1501 volta(e).
