Hyperlink Region - Add hyperlinks in SMath Studio worksheets/SMath Viewer - Messaggi
Ctrl-H "command +Click
Just to complete the early introduced feature
- converter on paste accept command-line strings (input string: "ProcessToStart"[space]Flags)
so when you paste in the placeholder something like:
"C:\Windows\system32\rundll32" sysdm.cpl,EditEnvironmentVariables
this will become:
"'C:\Windows\system32\rundll32' sysdm.cpl,EditEnvironmentVariables"
best regards,
Davide
Playing around with empty/nonempty or visible/nonvisible description prior to copying shows other glitches like frozen box size in the copy description. That might be secondary symptoms of the data handling problem.
If you copy using Ctrl-C Ctrl-V everyting is fine.
WroteStrange bug: If you copy a Hyperlink region with description using Ctrl-Drag, then both original and copy seem to use the same data. If you edit the copy, the original changes as well (also the cursor is shown there).
thank you, was my fault. Plugin updated.
Thanks for the work man.
Just a few quick questions,
lets say i wanted to open up a file with a specific program, what would i type into the hyperlink?
for example, lets say i wanted to open up
song.mp3
with the executable
C:\foobar\foobar.exe
Wrote,
song.mp3
with the executable
You might try the approach shown in post23.
Use "'C:\foobar\foobar.exe' song.mp3". It is essential to quote the executable path with ', otherwise windows takes the space as part of the prog name.
WroteYou might try the approach shown in post23.
Exactly
with foobar, if your song contains some spaces use wildcards (*) instead of spaces (f.e. this doesn't work in vlc; I'll think to another approach or another solution to fix this - maybe a double single quotation to have a double quotation or a context menu dialog...)
regards,
Davide
![2013-09-11 23_50_38-SMath Studio Desktop - [lalala.sm_].png](/it-IT/files/Download/bVvKxa/2013-09-11-23_50_38-SMath-Studio-Desktop---[lalala.sm_].png)
Amazing plugin websurfer.
- Flags input moved from the placeholder to a dedicated context menu item.
This solve double quotes issues involving flags and SMath strings.
- PASTE feature works also with the new input way.
(TEMPORARY feature) To update worksheets containing the old syntax ("'process' flags"):
- open the worksheet
- save the worksheet
- close and open again the worksheet
- delete all except the process name from the input placeholder
regards
Davide
![2013-10-07 02_22_09-VV.AA. - [n.d. #01] song 01 [foobar2000 v1.2.9].png](/it-IT/files/Download/FcSSFv/2013-10-07-02_22_09-VV.AA.---[n.d.-%2301]-song-01---[foobar2000-v1.2.9].png)
- Fixed critical bug on exceptions' propagation.
- SMath Studio 0.96.5146 required;
- restored red background when the region is disabled;
- click on resize markers now doesn't trigger the link.
best regards,
Davide
of executable version (viewer) doesn't work for me.
Is that known issue ?
After SMath was restarted it works.
Sorry for bothering you.
- Paste as SMath string temporary disabled (this let you paste strings on the canvas freely)
not sure if it is my issue only, but everything I paste becomes an hyperlink, formulas also.
The way I am working now it starting a dummy formula, paste what I need and then delete the rest. Am I missing something?
I tried to find a reference to this in the forum but did not succeed. I apologize if the answer is already out there.
thanks
PLUGIN UPDATED
- Paste as SMath string temporary disabled.
edit not a SMath bug, just a misinterpreted feature.
![2013-08-24 00_18_32-SMath Studio Desktop - [HyperlinkRegion.sm].png](/it-IT/files/Download/xd5VzB/2013-08-24-00_18_32-SMath-Studio-Desktop---[HyperlinkRegion.sm].png)
![2014-02-04 12_04_50-SMath Studio Desktop - [Page1_].png](/it-IT/files/Download/HNLTzx/2014-02-04-12_04_50-SMath-Studio-Desktop---[Page1_].png)
