Ploting Function
Ploting Function - Messaggi
#1 Pubblicato: 27/06/2011 15:06:01
LordArc
LordArc
0 apprezzamenti in 6 post.
at first a great acclamation for this Tool.
I'm using it in my Bachelor-Thesis and it is very helpfull.
At this point is will Draw a Plot of Current-Flow in Electrical Circuit.
For this i have a equation, but this will not be shown in the Plot-Windows.
PS: Is there still a developement in progress for SMath???
#2 Pubblicato: 27/06/2011 15:50:20
Gruppo: Moderator
I do not know if I understood you well, but the plot could not be drawn because of the wrong units.
Here is a possible solution:
As far as I know, Andrey is working on a new SMath version at the moment.
#3 Pubblicato: 27/06/2011 16:23:28
LordArc
LordArc
If i'm seeing it right you have inserted the Unit in the Plot.
When i trie to do this over the Ctrl+W Hotkey, SMath inserts "'s" and don't recognize it as Unit.
Then in the Argument is displayed "x's"
#4 Pubblicato: 27/06/2011 16:44:45
Gruppo: Moderator
My advice is to use multiplication between variable and unit.
1. this is not advisable
x[CTRL+W] ... and choosing Second('s) from the dialog box - it will produce "x's"
2. this shoud work
x*[CTRL+W] ...and choosing Second('s) from the dialog box
...or simply pressing
x*'s
(apostrophe ' will give you black circle as the placeholder - for inserting units - instead a regular black square)
BTW, Hotkey [CTRL + SPACE] will give you the Dynamic assistance - but it will not work in the 2D or 3D plot forms.
I hope this helped.
#5 Pubblicato: 28/06/2011 02:07:36
LordArc
LordArc
This was it!
Thank you very much!
#6 Pubblicato: 28/06/2011 14:21:32
LordArc
LordArc
Here i'm again.
Next Step and next Problem.
The Plot is only valid for the first Swing over Zero till first pass through zero.
So i tried to modify the definition of equation with the if and else function.
But sometimes SMath crashes and sometimes SMath still says no definition.
Also the solve function doesn't work at first try. SMath told that it was tried to divide by zero.
Someone one more hint for the right result???
#7 Pubblicato: 28/06/2011 17:16:00
Gruppo: Moderator
Again, I am not quite sure what did you want to do, sorry.
Nevertheless, I will try to give you an answer. If this does not solve your problem, just be more specific please.
Here it is:
Btw, it is advisable to avoid "x" as a function argument in the function definition (I used "X" here) when you try to make plots ("x" is reserved for 2D plots and "x","y" for 3D plots. For instance, this will not work. In some cases this will work, but for this particular one it does not (Do not know why).
#8 Pubblicato: 29/06/2011 03:36:51
LordArc
LordArc
At first i will try to specific more the behavior i need.
The Equation for IL let you calculate how current flows in a controlled transformer rectifier circuit with center tap.
But it is only valid for the period interval (in this case from 0 to 20ms because of the 50Hz Sinus). Then the fist Swing
you see in the Plot will be periodical repeated, if alpha doesn't change.
Alpha is the point were the Switch is turned on.
Because it is a two pulsed rectifier in the next step i will need to add the swing for alpha+pi/2, but i have at this time
enough problems with the first swing
As you see below, i have copied your resolution but it doesn't work at all.
No error message is given from SMath.
I'm yousing the stable release, should i switch to the actual beta?
#9 Pubblicato: 29/06/2011 05:01:42
Gruppo: Moderator
I think you should, there are some fixes in the recent beta.
Btw, you can make a plot this way (plotting a matrix with two columns)
#10 Pubblicato: 29/06/2011 08:25:33
LordArc
LordArc
I installed the Beta Version and now all works fine.
Also without plotting with the matrix.
Again a great thanks for your help!
