Novell ZENworks Application Virtualization Popup when running Smath
Novell ZENworks Application Virtualization Popup when running Smath - prompts user on how many days are left in trial - Messaggi
#1 Pubblicato: 19/06/2013 09:15:17
lcesero
lcesero
0 apprezzamenti in 8 post.
Hi Andrey,
I am getting a Novell ZENworks Application Virtualization Popup when running Smath
version 0.96 (build 4868). It is informing me that there are only 11 days left before the trial expires.
Louis
#2 Pubblicato: 19/06/2013 09:34:35
Gruppo: Moderator
Confirmed (SMath Studio 0.96.4868 portable)
regards,
Davide
#3 Pubblicato: 19/06/2013 10:25:36
Gruppo: Moderator
I confirm that with 4868.
With 4875 and following builds, there is no such problem.
#4 Pubblicato: 19/06/2013 10:47:43
kilele
kilele
134 apprezzamenti in 397 post.
Microsoft has a software for virtualization, App-V.
I don't know if it is free of charge.
http://www.microsoft.com/en-us/windows/enterprise/products-and-technologies/virtualization/app-v.aspx
http://rorymon.com/blog/index.php/category/app-v/
http://www.brianmadden.com/blogs/timmangan/archive/2013/06/07/simpler-faster-and-cheaper.aspx
#5 Pubblicato: 19/06/2013 12:10:07
kilele
kilele
I tried "Cameyo" and "Enigma Virtual Box", without success possibly because I didn't played with configuration parameters. Both are freeware, I'd try the second one since it is a freeware product provided for a company which sells other type of programs.
#6 Pubblicato: 19/06/2013 15:09:15
Gruppo: Super Administrator
Thank you for the info. It seems I have to finish using of Application Virtualization app for creating Portable versions (I just got a confirmation that finally ZENworks doesn't allow me to buy their product).
It was important because it includes .Net Framework 2.0 and allows users to use SMath Studio without requirement to install .Net Framework first.
Starting from Vista .Net Framework 2.0 is already preinstalled in the system, so I believe there is no need to support such kind of SMath Studio Portable anymore. Instead I will create a Portable packege without .Net included.
Regards.
#7 Pubblicato: 19/06/2013 15:30:18
kilele
kilele
Please consider to make a portableapps.com compatible package
#8 Pubblicato: 01/07/2013 08:20:59
Gruppo: Moderator
Expired
Only to mention it, the same problem appears in the 0.96.4883 portable.
regards
Davide
