Changing text size, color and background
Changing text size, color and background - Messaggi
#1 Pubblicato: 06/02/2009 10:24:44
sleschke
sleschke
0 apprezzamenti in 13 post.
It seems that you can not change the size, color and background of existing text.
The settings only apply to new text that is typed in.
If I select existing text and change the settings nothing will happen.
#2 Pubblicato: 06/02/2009 11:12:36
Gruppo: Super Administrator
Thanks, this is actual only for Handheld version. Will be fixed ASAP.
#3 Pubblicato: 08/03/2010 18:38:14
apluscw
apluscw
0 apprezzamenti in 2 post.
The same behavior is observable with the latest PC version. This is such a promising program, but not being able to change text is a pretty big weakness. I hope it is an easy fix.
I find SMath much easier to use than MathCad. While I really like MathCad, I hadn't used it for awhile and found it hard to get back into recently. With SMath, I was up and running in no time at all.
#4 Pubblicato: 08/03/2010 19:19:28
Can't reproduce it. After text area is created you need just select this text area (not the text inside) and then change preferred size and/or colors.
Thank you. Glad you enjoy it!
Best regards, Andrey Ivashov.
#5 Pubblicato: 08/03/2010 21:12:26
apluscw
apluscw
OK. What threw me is I had expected to be able to highlight the text in text edit mode and change the highlighted text. Normally, in most Windows apps, you can do that. If I highlight the text like I am going to move it, I can change the settings of the entire block of text.
Some additional feedback:
1. If you could change the text when highlighted it would be easier on folks like me that are used to editing text that way, plus it would allow mixed formatting within a text box. (Perhaps that is technically difficult to do?)
2. Having access to the conventional underline, italics and bold font options would be very appealing. I went back to highlight my text the way I had intended to and found the lack of those options very limiting.
