DISLIN
DISLIN - A high-level plotting library for displaying data - Messaggi
#41 Pubblicato: 04/04/2016 15:30:31
Jean, on a side note, what is your comment on a quality of DISLIN generated plots?
There are already so many 3D plots, many are freeware.
Scilab, DISLIN ... Surfer 8 [dedicated Contour plot, not freeware].
I see DISLIN via a menu driven and equation editor, Mathcad style.
The first thing is a the same CreateMesh than Mathcad. Let say the
two planes X, Y and the level Z plane and in parametric style.
That sets the complete 3 D system, meshed at will and supporting
the entire user rotation from command line as well as cylindrical/
spherical plots and export the corresponding matrices. Contour is
something else of much different nature. Contour plots ends being
an XY plot. I have a Mathcad contour program [done by Collab].
Just scared to attempt Coding in Smath. Some of you gurus, I can
make an image of the program for your bed time reading.
There remains the question about freeware: how far can somebody
reverse Engineer and redistribute ?
Cheers Alex, Jean
#42 Pubblicato: 04/04/2016 18:54:22
... that's what I meant about a comprehensive "DISLIN start".
Contour is for exporting specific contour data. The feed is a
matrix, either well populated or splined and you get what you
want. Collapse the function, plug the matrix from source or
from function ... ready for the contour(s), just few clicks.
I lost patience trying to imitate Mathcad "on error".
So, attempting the program is not tempting.
The program images included in the *.sm work sheet.
Contour Electron.sm (239,09 KiB) scaricato 2170 volta(e).
Alexander O. Melnik 04/04/2016 19:01:00
#43 Pubblicato: 27/10/2020 08:50:31
Gruppo: Super Administrator
Hello.
Currently I'm working to improve SMath Studio start up time. Have good results (made it up to 4x faster), but I've found that DISLIN plug-in requires from 4 to 14 seconds (different environment) to response on call to GetTermsHandled. Which is the most significant part of SMath Studio start up time.
Is it possible to improve the logic here?
#44 Pubblicato: 27/10/2020 09:02:58
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
I'll see what I can do or will change the way I use it.
Andrey Ivashov 27/10/2020 09:22:00, Davide Carpi 27/10/2020 11:02:00, sergio 27/10/2020 11:51:00
#45 Pubblicato: 04/11/2020 16:23:17
Gruppo: Moderator
Updated. Refactored. Startup time has been reduced.
Andrey Ivashov 05/11/2020 06:34:00
#46 Pubblicato: 04/11/2020 23:36:55
... native SS 6179 ... sorry but I have no interest *.svg
Stand alone user command line is more my cup of tea.
#47 Pubblicato: 05/11/2020 12:34:36
Gruppo: Moderator
EULA
Updated.
Changes:
- updated to DISLIN 11.3.3 (799 functions);
- refactored.
Citazione
Grant of Free Usage
You are allowed to use DISLIN for free. Either as a private person or in a
commercial or non-commercial environment. There are no limitations.
Click to enlarge
DISLIN. Example 1.sm (95,34 KiB) scaricato 2198 volta(e).
DISLIN. Example 1.pdf (287,2 KiB) scaricato 1517 volta(e).
Andrey Ivashov 05/11/2020 19:12:00, NDTM Amarasekera 05/11/2020 22:32:00
#48 Pubblicato: 01/06/2022 14:30:37
Gruppo: Moderator
SMath Studio compatibility
Plugin updated.
Changes:
- updated to DISLIN 11.5 (799 functions);
- string encoding bug fixed;
- refactored.
4 utenti hanno apprezzato questo post
sergio 01/06/2022 16:46:00, João Felipe Seráfico Melo 01/06/2022 21:58:00, NDTM Amarasekera 01/06/2022 22:30:00, Mark R Harris 02/06/2022 03:36:00
#49 Pubblicato: 29/01/2025 01:32:17
Plugin updated:
- Text descriptions added to the functions implemented in the plugin (>90% descriptions found).
Вячеслав Мезенцев 29/01/2025 02:03:00, Oscar Campo 29/01/2025 02:33:00, NDTM Amarasekera 30/01/2025 10:41:00
#50 Pubblicato: 29/01/2025 22:19:59
Gruppo: Moderator
Here you need to keep in mind that the source file with a list of functions is automatically formed using the template distinct.tt. Therefore, it is advisable to come up with a way of automatically adding a description to each function.
