Unit Problem
Unit Problem - Messaggi
#1 Pubblicato: 06/10/2025 19:03:00
Queen Isles
Queen Isles
0 apprezzamenti in 2 post.
I dont know what I am doing wrong Vn it should be in kips or lbs. I am new to the software.
#2 Pubblicato: 06/10/2025 20:01:47
127 apprezzamenti in 342 post.
The expression for Vn has the typical dimensional form; in fact, under the square root we have a quantity expressed as mass divided by length squared. In such cases one must downplay the automatic use of units of measurement. for example as shown below.
#3 Pubblicato: 07/10/2025 09:55:49
federico
federico
6 apprezzamenti in 8 post.
Please also pay attention to specify whether you want a mass to act as a mass or as its equivalent force.
If it is mass indeed, you should use lb or kg, but in case you want it to be threated as its equivalent force, always use lbf or kgf (or better, N or kN, this would remove any doubt).
SMath will handle everything in the proper way once you specificy forces in kgf, and consequent unit will remain consistent.
Bye
Modificato 07/10/2025 11:17:57
#4 Pubblicato: 07/10/2025 18:34:27
Queen Isles
Queen Isles
Thanks for your input, I made it work.
