Draghilev's method - Solving systems of nonlinear equations. - Messaggi
Hi Viacheslav. Your examples and procedure, but without plugins (except your XYPlot plugin)
Draghilev's method. Finding roots.sm (743,37 KiB) scaricato 1376 volta(e).
Fridel Selitsky 23/10/2018 07:11:00, Вячеслав Мезенцев 23/10/2018 12:42:00, frapuano 26/11/2018 06:35:00
WroteAs far as I can see there are no questions. As I said, everything is quite simple - we follow along the curve of n 1 space. Next, I will tell how to choose a start point, direction, and about the restrictions that follow from the method. I hope that the examples will be added.
From that 7 years old ... that works fine as downloaded,
but turns red as saved SS 6179, not doctored.
As offered in the attached, finding the max is acceptable.
The method suggested for the minima has not been tested.
As it looks: it fails ?
Mathhs NelderMead Himmelblau.sm (160,02 KiB) scaricato 1283 volta(e).
Maths Draghilev's method. Finding extremes. Himmelblau function version 0.2.sm (370,71 KiB) scaricato 1361 volta(e).
