Column sumation of a complex matrix
Column sumation of a complex matrix - I want to sum all numbers on a specific column - Messaggi
#1 Pubblicato: 15/10/2023 15:25:52
Tere Sergiu-Gheorghe
1 apprezzamenti in 2 post.
Hello guys,
I have a matrix with system of values in it. I want to sum up all the column.
Could you help me with this?
sumcomplexcolumn.sm (9,96 KiB) scaricato 1382 volta(e).
#2 Pubblicato: 15/10/2023 17:33:50
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
It's necessary convert each system of your 5th column to a matrix by sys2mat() function, then you can stack each matrix from 5th column and do the summation:
sumcomplexcolumn SOLVED.sm (12,77 KiB) scaricato 1373 volta(e).
Oscar
#3 Pubblicato: 15/10/2023 18:01:59
ioan92
ioan92
181 apprezzamenti in 125 post.
Hi Sergio,
Of course, Oscar’s proposal is a very interesting one
May I make a simple suggestion: avoid the use of “sys” data and replace it with a simple sum, as in my appended file.
Best Regards,
Ioan
If the column's sums are aasked, here is a solution for keeping the answer inside the box...:d
sumcomplexcolumn (1).sm (11,7 KiB) scaricato 1385 volta(e).
#4 Pubblicato: 15/10/2023 18:09:35
Oscar Campo
Oscar Campo
Gruppo: Moderator
Hi Sergio,
Best Regards,
Ioan
Nice!, you think out of the box :d
#5 Pubblicato: 15/10/2023 20:32:04
Doctored version from construction.
sumcomplexcolumn.sm (9,96 KiB) scaricato 1409 volta(e).
#6 Pubblicato: 15/10/2023 20:41:06
Thank you very much guys for your answers!
I bought the paid version of smath also because this forum has such great users.
Oscar Campo 16/10/2023 22:26:00
