1 pagine (7 elementi)
"Cannot find file" error on saving - "Cannot find file" error on saving - Messaggi
WroteAny help will be much appreciated
Try disable AV's [Anti Virus] before saving.
Peter J Francis 25/08/2022 11:48:00
Hi Jean
Thanks for the reply , I tried that .... still get the error
I've also tried it on 2 different PCs with no luck
Peter J Francis
Twitter: @PeterJFrancis
Thermal Engineer , Maker , Pilot
WroteHi Jean
From recollection, I think Davide could recuperate.
Wait and expect SS Community will help.
- Update SMath to latest stable (1.0.8253),
- Update all installed plugins to latest versions,
- Try to run SMath as administrator.
Peter J Francis 30/08/2022 04:06:00
The error message seems related to something in the ImageEditRegion plugin
<ProjectGuid>{63DDAEF8-9A56-4FF6-938E-D590B638BF99}</ProjectGuid>
Thanks Davide,
I just disabled ImageRegion plugin and the error disappeared when i saved the sheet
Overlord - thanks for your answer
I can't upgrade to the latest stable yet as the client is using the same version as I am
thank you all for your help
Peter
Peter
Peter J Francis
