Problem with simple 2D plot
Problem with simple 2D plot - Messaggi
#1 Pubblicato: 19/07/2021 12:41:14
trawqa18
trawqa18
0 apprezzamenti in 6 post.
Hi everyone. In work I used MathCad, but when I heared about Smath Studio - I wanna try it at home. But..... I have problem. I want to rewrite one calculation sheet from MathCad to Smath.
Here is fragment from MathCad: 1.PNG
I try to rewrite the same calculation to Smath but I can't correctly generate plot: 2.PNG
What I do wrong? I can't find error. BTW: I can't apply "x" range like I made it in MathCad.Can someone help me? Maybe make simple working file with solution on my problem? I already don't have any idea... I try for few days after works.
#2 Pubblicato: 19/07/2021 13:46:10
Gruppo: Moderator
Here is your worksheet.
Smath don't have mathcad x define while plotting.
We generally augment x with results.
While unit version shall plot too, better to make eliminating a habbit.
PS: updated post with cases(), a simpler and easier if() replacement.
mg(x).sm (15,57 KiB) scaricato 1210 volta(e).
#3 Pubblicato: 19/07/2021 14:32:10
trawqa18
trawqa18
Thanks MAN! Now I have starting point
How you define Mg? This arrow came from?
#4 Pubblicato: 19/07/2021 15:21:33
Gruppo: Moderator
That is vectorize() function.
You can either type it as a function or select from toolbar.
#5 Pubblicato: 20/07/2021 08:22:45
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
Hi!
Here is a little different way to express your model and find your answer, maybe it could be interesting:
You can download the Smath file here: BySingularityFunctions.sm (25,07 KiB) scaricato 1207 volta(e).
Regards.
#6 Pubblicato: 20/07/2021 11:21:04
mg(x) More for Convenience.sm (17,33 KiB) scaricato 1201 volta(e).
#7 Pubblicato: 27/07/2021 13:12:17
trawqa18
trawqa18
I wanna to have mm on plot "x". How can I change that?
I'm trying to make this file in Smath (Yi n'Yama n'syuc - Rolka jezdna.pdf (211,06 KiB) scaricato 776 volta(e).
#8 Pubblicato: 27/07/2021 14:16:12
I try to make Mg(x) fragment on my own... How you done this?
Fragment as suggested 3 different ways.
No system will respond to invented code.
#9 Pubblicato: 27/07/2021 14:28:49
trawqa18
trawqa18
I'm try to understeund how somebody write it... I can't reproduce that record.
I mean, I don't know in what order I must click specific function to get this "function"
#10 Pubblicato: 27/07/2021 14:50:21
Gruppo: Moderator
The symbolic stuff is, from outer to inner:
line(
vectorize(
cases(
cases is from "custom functions" plugin, therefore to have it in your functions you have to install the extension first.
line and vectorize are available also in the toolboxes on RHS of the worksheet area.
About unit scaling, divide by 'mm instead of 'm (a mm is 1/1000 m, so the output will be magnified by a 10E3 factor)
#11 Pubblicato: 27/07/2021 15:25:18
I'm try to understand how somebody write it... I can't reproduce that record.
Here is the 4th code ... set 'n' as you wish to fragment.
#12 Pubblicato: 27/07/2021 15:30:42
trawqa18
trawqa18
Davide, that is what I'm talking about. Thanks man!
