1 pagine (4 elementi)
Stable: SMath Studio 0.94.4523 (20 May 2012) - Messaggi
New SMath Studio 0.94.4523 Stable available
Absolutely free mathematical program with "paper"-like interface and numerous computing features (now with integrated mathematical reference book).
SMath Studio Desktop on the Desktop (Windows)
SMath Studio Desktop on the Desktop (Linux)
Last changes
- Picture Region improved to support scaling and read-only mode;
- Picture Region improved to be automatically fitted to the page width on Picture insert if page layout specified;
- Added support for colors specifying for the special objects and strings into the Plot Region using web format (like #6699CC);
- Function sum(1) now built-in to the program;
- Continue and Break statements implemented.
- Area Region improved to support multi-language feature for the Area titles;
- Added ability to set title for the Separator Region;
- Descriptions can be now used not only for Math Regions but for any evaluable regions like Plot Region;
- Pound-mole (lbmol) built-in Unit added;
- Added ability to start SMath Studio in silent mode using '-silent' argument next to the list of worksheet files to process files without starting SMath Studio GUI;
- Handling of arguments separator keying improved in Math Region;
- Added ability to add a new cell to the vector/system/line by keying arguments separator;
- Error handling corrected to indicate whether it is not possible to define element of the nested arrays using el(..) function;
- Unit conversion corrected when working with operations like (1/a)^b -> 1/a^b;
- Default Text Region font name now don't exported to .sm/.smz file saving;
- Several critical/calculation issues fixed usually appeared on complex units evaluation;
- Fixed issues when Description of the evaluable region become empty after file save/load cycle.
- Fixed issue when undesirable brackets appeared sometimes around the pasted math expressions;
- Fixed critical error of Text Region appeared sometime on Cut/Backspace operations;
- Fixed error tooltip location issue when Region for the tooltip located between two Collapsed Areas;
- Fixed issue when Separator cannot be moved by the mouse;
- Fixed error appeared in some cases when big numbers processed with symbolic engine ("xE" error);
- Fixed error appears for min/max functions when working with zeros and other values that includes units;
- Fixed issue when it was impossible to use trailing zeros option for zero results;
- Fixed issue when some functions are shown twice in the Insert Function dialog;
- Fixed critical error appeared on removing of empty cell from the vector/system/line functions if nested matrix/system/line exists there;
- Critical error appears on Region remove if the Region focused and located after the collapsed Area fixed;
- Fixed Region's selection error appeared sometime on fast mouse clicks;
- Fixed new Region painting issue if a Region added to the top left corner of the Worksheet;
- Fixed error of defining matrix elements using symbolic optimization;
- Fixed critical error appears on evaluation if manually assigned result Units contains any math error;
- Fixed simplification errors of the boolean operators related to wrong sign of the result expression;
- Fixed errors of the operations with matrices and scalars in symbolic library;
- Examples improved;
- Refactoring.
Changes since SMath Studio 0.94
- Critical error fixed appeared on changing Description language of the set of evaluable Regions when one or more Regions in the set has no Description at all;
- Calculation errors fixed in symbolic library for the following expressions: sin(atan(x)), cos(acot(x)), tan(asin(x)), tan(acos(x)), cot(asin(x)) and cot(acos(x));
- Working with multi-language enabled Text Regions improved;
- Resizing of the Picture fixed;
- Critical error appears on operator keying fixed;
- Product function button on the right panel fixed;
- Sum function button on the right panel repaired to insert sum(4).
System requirements
- Desktop (Windows):
Framework: .NET Framework 2.0 - Desktop (Linux):
Interface languages
Desktop and Handheld (34 languages):
Free Download
SMathStudioDesktop.0_94_4523.Setup.msi (Date: 20.05.2012. File size: 1.75MB)
SMathStudioDesktop.0_94_4523.Portable.exe (Date: 20.05.2012. File size: 17.98MB) - .Net Framework 2.0 doesn't required - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_94_4523.Mono.tar.gz (Date: 20.05.2012. File size: 839.27KB) - last version of Mono distributive required!
Note: No current version of SMath Studio Handheld release will be introduced. Please use the latest stable handheld version (0.90).
Tutorial
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
Other files
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
4 utenti hanno apprezzato questo post
Radovan Omorjan 21/05/2012 04:51:00, matteob8 21/05/2012 05:15:00, Davide Carpi 21/05/2012 05:16:00, Oscar Campo 22/05/2012 11:16:00
Thanks for fixing the pi product function and for using sum(4) instead of sum(1) in the right-hand side palette.
Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University.
- unfortunately not possible to delete an imported picture
+ picture scale works fine
Wrote- unfortunately not possible to delete an imported picture
