Spline-Lagrange-Knots
Spline-Lagrange-Knots - Spline-Lagrange-Knots - Messaggi
#1 Pubblicato: 05/04/2019 17:51:44
1. This type of spline is for high Technical/Scientific works.
2. It roams around points, governed by the vector of knots.
3. Not easy to manipulate: trial/error for best fit.
4. Most likely it will crash Smath ... save a working copy.
5. Supports indirectly integration [via Smath ainterp typical].
6. Supports infinitesimal derivative ...
at this point: you may adjust the vector of knots from
visual inspection of the derivative.
Spline0 Quadratic Lagrange Knots.sm (38,28 KiB) scaricato 1250 volta(e).
Andrey Ivashov 06/04/2019 13:00:00
#2 Pubblicato: 06/04/2019 11:58:57
... refactored for publishing.
Spline Lagrange of higher order exist, not conserved.
Spline0 Quadratic Lagrange Knots.sm (70,18 KiB) scaricato 1243 volta(e).
