1 pagine (6 elementi)
Combobox Return Multiple Values - Messaggi
You can also use ranged indices to pick any column you need listed in the order you prefer, without any change in the input matrix.
This is an example using either the item row or the item index
![2022-11-10 10_39_12-SMath Solver - [Worksheet1_].png](/it-IT/files/Download/s7vKSe/2022-11-10-10_39_12-SMath-Solver---[Worksheet1_].png)
Thank you guys! This is exactly what I was looking for.
One more question if you don't mind. Is is possible to set the results to a different variable? For example. I want the 1500 value to be "vn" and the 15 value to be "Ga". This way the equations will make more sense if someone is reviewing them.
Thanks!
Thanks!
Yes that is exactly it.
![2022-11-11 10_40_09-SMath Solver - [shething.sm_].png](/it-IT/files/Download/rFKQsA/2022-11-11-10_40_09-SMath-Solver---[shething.sm_].png)
