Compacting syntax?
Compacting syntax? - Messaggi
#1 Pubblicato: 10/07/2018 18:59:22
dio pants
dio pants
16 apprezzamenti in 180 post.
I have an include file with a bunch of functions and variable definitions in it. Within one of my functions is a 'cases' and a bunch of if/thens that makes it REALLY long.
Are better ways to script or format the syntax for something like this? The sheer vertical size of this trips me up sometimes and I need to get my bearigns to navigate it.
Thanks
Dennis
#2 Pubblicato: 10/07/2018 21:13:29
Are better ways to script or format the syntax for something like this ?
For horizontal, use if/otherwise instead of if/else
Open the collapsed area [mapR(x), mapG(x),mapB(x)].
Image Rainbow Colormap [Electron].sm (252,09 KiB) scaricato 992 volta(e).
#3 Pubblicato: 10/07/2018 22:09:10
dio pants
dio pants
Jean Giraud-
THANK YOU! that will help me make things so much cleaner. I need to take some time to get my head around the way I have it now to clean up.
Question- at the value of say 64, do the sucessive (32≤x)&(x≤64) and (64≤x)&(x≤96) have a conclict? should one of those terms be a less than instead of a less than or equal too operator?
Dennis
#4 Pubblicato: 10/07/2018 23:22:22
... can't tell w/o the document. On top, you complicate matters
Can't you mange f(x) ... linterp(X,Y,x)
... or part of the document that produces something.
#5 Pubblicato: 11/07/2018 11:19:35
dio pants
dio pants
Jean Giraud-
My question is about the bolean expressions in your example, within the mapR(x) section. Two sucessive expressions have a common intersection point throughout.
1. The upper limit of the first expression is a less than or equal evaluation of a number.
2. The lower limit of the next expression is a greater than or equal to the same number.
What happens when the value for the expression is exactly equal to the number?
I thought only one of the two expressions could be an 'equal to' statement at the same limit point.
Dennis
#6 Pubblicato: 11/07/2018 13:14:55
... mistakes in the last two posts, deleted.
The two segments for interpolation.
Dennis.sm (11,09 KiB) scaricato 1172 volta(e).
#7 Pubblicato: 13/07/2018 21:44:53
dio pants
dio pants
Jean Giraud-
Thanks for that explanation. I actually learned a whole bunch more functions from that too!
Dennis
#8 Pubblicato: 14/07/2018 01:54:32
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
You can use areas to separate portions of code.
As an example, please, look this game that I developed and has a lot of lines of code
Regards!
