@Air
@Air - @Air provides thermodynamic properties and transport properties of moist air. - Messaggi
#1 Pubblicato: 19/07/2013 06:56:52
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Functions list: AirPTWV(), AirPVWT(), AirTVWP(), AirPTW(), AirPTF(), AirPWD(), AirPTRW(), AirPTWR(), AirPTWB(), AirPTBW(), AirPBWT(), AirPBRT(), AirPTWU(), AirPTUW(), AirPTWH(), AirPWHT(), AirPHWT(), AirPTWS(), AirPWST(), AirPSWT(), AirVapPT(), AirVapTP(), AirCondPTH(), AirCondPTS(), AirPTWM(), AirPTWK(), AirPTWC(), AirPTHs(), AirPHTs(), AirWX(), AirXW(), AirVer().
Dependences: Mathcad EFI plugin.
Short description:
Mostra spoiler
Links:
1. Mcdair32.dll you can get from here: @Air 4.0 (or from archive below).
You must manually copy the Mcdair32.dll to the userefi folder (".../Application Data/.../91a20d24-c30b-4774-9b1b-4d502a80420f/x.x.x.x/userefi/" ) and TAir32.dll to the \windows\system32\.
air.zip (81,87 KiB) scaricato 627 volta(e).
#2 Pubblicato: 19/07/2013 08:24:32
kilele
kilele
134 apprezzamenti in 397 post.
Uni, thank you very much!!
May glory and renown follow you, and gold and w****
Some of these resources could be serve to complement your plugins :
http://en.smath.info/forum/yaf_postsm9354_Built-in-Thermodynamic--and-other--Tables.aspx#post9354
Thanks again and have a nice summer
#3 Pubblicato: 19/07/2013 09:36:32
Gruppo: Moderator
Unfortunately, all of these tools (WinSteam, @Air and @Gas) are free only for 30 days.
#4 Pubblicato: 19/07/2013 09:43:01
Gruppo: Moderator
Does it count using them in SMath as well?
#5 Pubblicato: 19/07/2013 10:16:16
Gruppo: Moderator
I found a link to them on the PTC forum: WinSteam Functions in MathCad. These guys get paid for both these tools: Mathcad and WinSteam. They could pay only for one.
#6 Pubblicato: 19/07/2013 12:56:43
kilele
kilele
I installed WinSteam and @Air, grabbed McdStm32.dll and Mcdair32.dll, put them into userefi folder and then uninstalled both softwares. SMath does not get to load the plugins reporting the following errors "Tair32.dll not found" ; "TSteam32.dll not found".
#7 Pubblicato: 19/07/2013 13:06:41
Gruppo: Moderator
Copy these two files too (from \WINDOWS\system32\). The fact that Mcdair32.dll and McdStm32.dll are intermediaries of these libraries and do not contain functions themselves. Mathcad libraries contain wrapper functions, they can't work independently.
EDIT: Do not copy. They must be in \system32\ directory. When you uninstalled the program, these files have disappeared. SMath Studio tries to load Mcdair32.dll and it tries to load TAir32.dll. Usually it is sufficient to put the library in the same place where the mathcad library is located. But not in this case.
