1 pagine (7 elementi)
[SS-2300] Greater than Or Equal To - If statement returns wrong value - Messaggi
It seems odd that I am finding this problem now. Maybe it is a recent bug. Or maybe I am doing something wrong?
Both statements should return b:=1 but when I add the unit of feet. There is a problem.
Any thoughts?
Thanks!Greater than or Equal to.sm (3,7 KiB) scaricato 1284 volta(e).
Any thoughts?
It seems that it is a rounding problem in internal transformation of SMath from ft to m.
In fact, with x = 3.0001 ft the problem does not exist.
it is SS-2300
I'm not sure how I haven't noticed this before. Anyway, thanks!
Another Work Around:
Greater than or Equal to_2.sm (5,28 KiB) scaricato 1307 volta(e).
What is the best way to post embedded photos on this site? Typically I use onedrive for storage (fyi).
WroteWhat is the best way to post embedded photos on this site? Typically I use onedrive for storage (fyi).
Simply add an attachment, like for *.sm/*.smz files.
1. You must be in the "Post reply" mode
2. Where you leave the cursor: click on the clip
"Insert an existing attachment or upload a new file"
look for it in your PC, double click, click "Post".
If you have multiple attachments at the end of your message,
keep adding. Before posting final, put the cursor after the
first attachment, press "Enter".it will pile down ...
keep doing that up until they are all piled down...Post final.
All that works for "images"
and work sheets *.sm1 utenti hanno apprezzato questo post
Davide Carpi 05/01/2017 15:53:00
