Writer Region Plugin
Writer Region Plugin - Provides the ability to work with formatted text inside the Worksheet. - Messaggi
#61 Pubblicato: 14/10/2016 19:55:41
Alexander O. Melnik
Alexander O. Melnik
127 apprezzamenti in 498 post.
Gruppo: Moderator
Good Day Davide,
I have used the "Field" functionality for a while now, in particular the "date" and the "worksheet info".
I have noticed that:
1. worksheet info field does not change if the actual smath file properties change
2. date changes the moment smath worksheets is re-opened
Is there a particulat reason for this behaviour? If you consider my suggestion worthwhile I propose to update the worksheet info fields every time the .sm file is opened to scan for changes. Also I propose to update the "date" field only when it is created or copied/cloned elsewhere - it would make sense to track the date when a particular calculation page in a .sm worksheet was created, not the current date/time at the instance of .sm file access.
A.M.
#62 Pubblicato: 16/10/2016 12:58:06
Gruppo: Moderator
Hello Alex,
Yes, this is because the region is designed to have a low footprint and there isn't an event "File Properties Changed" for the worksheet; but I see that it doesn't changes even on file opening nor for region paste; I'll investigate it ASAP.
I suppose is matter of my habits; if I need a static date/time I write it directly or I convert the field to static text. However I realize that one might want it "less dynamic". What if I add a property for each field to drive the update? (whenever possible or just manual by context menu).
Alexander O. Melnik 17/10/2016 13:04:00
#63 Pubblicato: 17/10/2016 13:06:03
Alexander O. Melnik
Alexander O. Melnik
Gruppo: Moderator
Hello Alex,
Thank you, Davide, both tweaks will be very much welcome, if and when you have time, of course.
Davide Carpi 17/10/2016 18:24:00
#64 Pubblicato: 02/11/2016 14:57:10
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.98.5935 and later
  • Rendering logic refactored to be much more fast (smooth worksheet's scroll on huge regions or even on multiple regions intersecting the viewport);
  • Applied correction on characters' spacing to make them closer to common text editors;
  • Fields: added option to disable automatic updates;
    Mostra spoiler
  • Fields: fixed Worksheet's metadata not updated on file open/region paste;
  • Spell checker import tool: dictionary packages now are loaded directly (no needs to unpack them);
  • minor fixes;
  • refactoring;
  • documentation updated;
sergio 02/11/2016 17:00:00, Alexander O. Melnik 02/11/2016 17:08:00, Ciro 04/12/2016 16:29:00
#65 Pubblicato: 12/01/2017 12:12:34
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.98.6179 and later
  • fixed performances issues on print preview;
  • added overline style (CTRL+SHIFT+O);
  • fixed text color change vs fields;
  • minor fixes;
  • refactoring;
Вячеслав Мезенцев 13/01/2017 01:45:00, NDTM Amarasekera 12/01/2017 12:45:00, sergio 12/01/2017 13:16:00
#66 Pubblicato: 03/03/2017 16:41:07
Ruben Sidranski
Ruben Sidranski
17 apprezzamenti in 465 post.
Davide,
Under version 0.98 build 6179 (64 bit) loaded, this plugin does not work as it used to. It used to be that CTR+Shift+W would pop open a "formatting" dialog box (per post #2 "floating toolbar") like the text region utilities. Now it just opens a "text box which is the width of the sheet, but no formatting utilities. Is this because 64 bit loaded up when I upgraded?
PS Same issue with portable version I created with previous version. Can shis toolbar be placed in the side panel with the math/symbols, etc.?
PPS If I left mouse click and go to settings, the floating toolbar pops up. Is there a way to make this the default? (both desktop and portable)
#67 Pubblicato: 03/03/2017 20:55:19
Gruppo: Moderator
Davide,
Really strange
Only cases in which you should notice changes are on cleaning of settings folder (but this will load the default settings, that aren't the ones listed by you) or by your choice. Please check your settings in the "More..." > "Options..." menu ("New regions" and "Environment" tabs). Settings should be saved once you click on "OK" and never change, except in cases mentioned previously.
Nope. Since next SS relase should be possible to create plug-ins to have more toolboxes, but this won't be the place for Writer Region toolbars.
Mostra spoiler
IVR 04/03/2017 13:01:00
#68 Pubblicato: 08/03/2017 08:13:00
Gruppo: Moderator
  • [critical] Fixed blue bleeding worksheet on history UnDo after deleting regions;
  • [critical] Fixed regions saved as empty when data pasted on canvas and no more edited;
NDTM Amarasekera 08/03/2017 12:57:00, Alexander O. Melnik 08/03/2017 11:27:00
#69 Pubblicato: 08/03/2017 09:36:53
My procedure Win 7, micro laptop:
1. from the insert menu => click the W symbol [insert writer region]
2. the empty rectangle appears [|]
3. click right for the drop down menu => click left "settings"
4. as you start typing in the rectangle the movable tool bar is active.
#70 Pubblicato: 08/03/2017 11:28:07
Alexander O. Melnik
Alexander O. Melnik
Gruppo: Moderator
Thank you for a prompt fix, Davide.
Davide Carpi 08/03/2017 20:38:00
#71 Pubblicato: 17/03/2017 10:57:52
Ruben Sidranski
Ruben Sidranski
Jean,
That is the problem! The movable tool bar is active only after doing all that. It used to pop up @ step #1.
#72 Pubblicato: 17/03/2017 11:21:16
Gruppo: Moderator
Have you tried to change your settings?
ElSid 17/03/2017 12:26:00
#73 Pubblicato: 17/03/2017 12:29:35
Ruben Sidranski
Ruben Sidranski
Environmental --> Popup toolbar --> On new region.
I just did a fresh install and the setting is sticking. Need to confirm on my portable version later tonight as I left my drive at home ...
Davide Carpi 17/03/2017 12:44:00
#74 Pubblicato: 17/03/2017 22:21:52
That is the problem!The movable tool bar is active only after doing all that.It used to pop up @ step #1.
Once you have entered the writer region you have minimal options:
click on a word to Ctrl+B, Ctrl+U [bold, underline].
For the tool bar: click right, click left on 'settings'.
The minimal and advanced options is very ergonomic [to me].
#75 Pubblicato: 07/09/2017 10:53:55
Ruben Sidranski
Ruben Sidranski
Davide,
Where do we download the dictionary packages?
As a request, is there a way to override the default SMath text with this plugin?
UPDATE: First post points to FF, APACHE or LibreOffice ... I am trying the LibreOffice version in English
Now, is there a way to spell check the whole document or is it region by region?
#76 Pubblicato: 07/09/2017 15:11:36
Gruppo: Moderator
UPDATE: First post points to FF, APACHE or LibreOffice ...I am trying the LibreOffice version in English
Yes, some links are in the documentation file
Nope, region-by-region, at least for now. I've plans for this.
#77 Pubblicato: 10/11/2017 11:57:18
pierre
pierre
2 apprezzamenti in 17 post.
First,
Thanks a lots for this amazing pluggin.
I have two little problems with the Pluggin.
First, when i hopen the *.sm file with notepad and save it, it can't open the file with Smath.
Secondly, if i set as default profile a paragraph with indentation, it creates an error for the copy paste.
It is not a big issue for me, but i just wanted to raise the problems.
Thanks again for your work.
#78 Pubblicato: 10/11/2017 13:38:05
Gruppo: Moderator
First,
Thank you for reporting these issues
Can you attach a small example of file that you cannot save with notepad? It is enough to open and save it to trigger the issue or you have to edit it?
#79 Pubblicato: 13/11/2017 08:34:40
pierre
pierre
Hi david,
I have checked at work, the following thing:
Test 1 : I create an empty spread sheet, create writter region with no indentation, save the doc, create a new empty doc, and copy paste the:
Citazione
Test
It works
Test 2 : I create an empty spread sheet, create writter region with indentation, save the doc, create a new empty doc, and copy paste the
Citazione
Test
It works
Test 3: I create an empty spread sheet, create writter region with indentation, set the setting as default style, Create a new region, save the doc, i cant open it again. The code of the second region is
Citazione
test2
If i delete this part of the file, i can't open the doc again, But if i delete the property ; margin-left: 36pt; it works.
TL;TR The difference is the following:
Citazione
style="margin-left: 36pt">Test
; margin-left: 36pt; line-height: 115%">
test2
I hope it helps,
And sorry for my poor english
Davide Carpi 14/11/2017 04:55:00
#80 Pubblicato: 22/12/2017 12:58:25
Nicolae Olaru
Nicolae Olaru
1 apprezzamenti in 115 post.
Greetings.
In MathCAD, it is possible to obtain symbols consisting of two (or more) words separated by the pause, as in the attached picture. The practical way I have identified for this purpose is to copy the two (or more) words from a text region and place them in the first empty field of equality of definition. My question is: Is there similar feature in SMath? If so, how to proceed?
All the best.
