1 pagine (10 elementi)
Nightly build: SMath Studio 0.97.5283 (19 June 2014) - Messaggi
Nightly build: SMath Studio 0.97.5283 available
Latest changes (against SMath Studio 0.97.5280)
- SS-143: Freezing of the application fixed on some copy/paste operations;
- Fixed removing of Regions based on RegionHolder when placeholder is empty;
- Fixed issue when useless brackets appeared between operands;
- Insert Unit dialog improved to allow displaying properties as dimensions if defined.
Download
SMathStudioDesktop.0_97_5283.Setup.msi (Date: 19.06.2014. File size: 1.77MB) - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_97_5283.Mono.tar.gz (Date: 19.06.2014. File size: 983.14KB) - last version of Mono distributive required!
7 utenti hanno apprezzato questo post
Davide Carpi 18/06/2014 19:29:00, Mikka 19/06/2014 00:10:00, sergio 19/06/2014 13:55:00, IVR 20/06/2014 08:49:00, Radovan Omorjan 21/06/2014 06:21:00, Вячеслав Мезенцев 21/06/2014 06:39:00, ioan92 21/06/2014 08:36:00
The new version affects the image region, see issue SS-165. Are there changes required by design or is that an unintended collateral effect?
Andrey, method UnitInfo.GetCurrentUnitName() was removed from ioman.dll (SMath.Manager.UnitInfo class) and what to do now? It was used in the include plugin.
EDIT: UnitsManager.GetCurrentUnitName() ?
WroteUnitsManager.GetCurrentUnitName() ?
Yes, it is correct.
I can't download the file.
WroteI can't download the file.
What file you can't download?
WroteWroteI can't download the file.
I can't download SMathStudioDesktop.0_97_5283.Setup.msi
it returns: Server Error in '/' Application.
Really strange, works for me (now and even yesterday)...
OS: Win 7 x64
Browsers: Chrome, Firefox, Firefox (using DownThemAll extension)
tried also using a proxy service (anonymouse.org)
OS: Win 7 x64
Andrey Ivashov 02/07/2014 14:38:00
WroteI can't download SMathStudioDesktop.0_97_5283.Setup.msi
Thank you for the info!
Could you please try to download file again? I think I found the reason and just fixed it.
Please let me know about results.
Best regards, Andrey Ivashov.
Davide Carpi 03/07/2014 10:04:00
