Integrating summations
Integrating summations - I looking for a way to integrate summations as a function of x - Messaggi
#1 Pubblicato: 20/02/2019 18:47:27
wvcamden
wvcamden
0 apprezzamenti in 10 post.
I have an equation that is dependent on the summation of terms and I need to integrate that equation. I can do it if i evaluate the summations myself but I am going to need many terms and was wondering if there is a way to do this without having to evaluate it myself?
I have attached a file of the equation I am trying to integrate.intsum.sm (12,8 KiB) scaricato 1179 volta(e).
#2 Pubblicato: 20/02/2019 19:45:22
Hi Camdem. Use line(...) for prevent the evaluation in Phi.series function. Then, integral could be evaluated.
intsum.sm (12,88 KiB) scaricato 1213 volta(e).
4 utenti hanno apprezzato questo post
Вячеслав Мезенцев 20/02/2019 20:11:00, wvcamden 20/02/2019 20:38:00, sergio 21/02/2019 07:27:00, frapuano 21/02/2019 14:43:00
#3 Pubblicato: 20/02/2019 20:38:34
wvcamden
wvcamden
Thank you very much Alvaro
#4 Pubblicato: 20/02/2019 22:03:23
Just a comment: the creation of the signal is so involved
that makes me doubt it come from Scientifics [just personal].
If it comes from a data set, tentatively approximated, it may
have much simpler representation.
I can look at it if interested, just the data set.
#5 Pubblicato: 21/02/2019 02:42:14
I
... would be much better from original data set.
If not appreciated: will delete all my replies.
#6 Pubblicato: 21/02/2019 11:23:42
wvcamden
wvcamden
Jean,
I appreciate what you have said and done so far. Unfortunately, though, the equation is from a series approximation of the equation I have attached. It doesn't come from a data set.
This attached equation is a solution to the diffusion equation with a non-uniform source.
#7 Pubblicato: 21/02/2019 12:27:32
... NO attachment !
#8 Pubblicato: 21/02/2019 12:48:14
wvcamden
wvcamden
Jean,
The attachment I was referencing was the picture of the equation.
analytic.sm (2,58 KiB) scaricato 1219 volta(e). Here is the equation in smath.
Sorry about the confusion.
#9 Pubblicato: 21/02/2019 13:15:34
... you mean S(x) approximates experimental data collection.
Why not integrate Φ.analytic(x) ?
There may be much suitable model than series approximation.
Quite a few Scientific works have never been done yet except in Smath:
Kirby, Han, Turber, Ant Colony, Termocouples [T,J]
RTD, Germanium -273.15, Copper in high magnetic induction ...
I have 100's model functions [addicted for more than 50 years].
Often, just look at raw data ... got the model or best fit.
Best success ... don't hesitate for + + +
Watch what you borrow from Others, I mean S(x).
#10 Pubblicato: 21/02/2019 13:31:43
wvcamden
wvcamden
Jean,
S(x) is the function that the source follows, it defines the value of the source at each point along the distance in the medium and is given for the medium.
On the grounds of integrating the analytic(x), I actually am elsewhere. I am comparing the series solution to the analytic solution to show that the series solution is a good model once enough summation terms are added. In some cases, the diffusion equation will not have an analytic solution and the series solution is necessary to model the system. therefore, I need to show that the series solution is valid.
In terms of other models, I have been instructed to use the series solution that I have.
Sincerely,
Cam
#11 Pubblicato: 22/02/2019 01:36:49
Jean,
On the grounds of integrating the analytic(x), I actually am elsewhere. I am comparing the series solution to the analytic solution to show that the series solution is a good model once enough summation terms are added.In some cases, the diffusion equation will not have an analytic solution and the series solution is necessary to model the system.therefore, I need to show that the series solution is valid.
In terms of other models,I have been instructed to use the series solution that I have.
Sincerely,
Cam
Thanks Cam, you express yourself very well.
I retain that on some experiment S(x) is not profitable,
then in lieu you propose the trig summation ... Ah !
Therefore: you construct accordingly to what S(x) fails.
At this point, and assuming that the "Camel shape" does not
do too much "monkey branching", linfitCheby is a much better
candidate as you just need to set the ChebyShev oder.
The final export is a gracious function ready for scientific calculator.
"linfitCheby" resulted for the extension of the Mathcad built-in 'linfit'.
More can be done as we can mask some components.
Two more candidates are valid: OVNI model, Fourier Budapest 39
More data sets are needed to examine their applicability.
Cheers Cam ... Jean
Genfit linfitCheby.sm (77,25 KiB) scaricato 1156 volta(e).
#12 Pubblicato: 22/02/2019 19:42:24
wvcamden
wvcamden
Jean,
Thank you very much for pointing out those other candidates. I appreciate all that you have said.
Sincerely,
Cam
