Programmer palette and complex numbers
Programmer palette and complex numbers - Messaggi
#1 Pubblicato: 07/03/2011 07:19:02
marcin
marcin
0 apprezzamenti in 2 post.
Precondition:
- smath_0_89_8 portable
- Wndows XP
Test steps:
1. Create new SMath document
2. Create some procedures with complex numbers
3. Put “Programmer palette” with “for” loop (with no influence on formula from step 2)
4. Put over and under “Programmer palette” result of some complex numbers counting result
Expected resul:
the same values should be shown
Result:
Difference values are shown
Remark:
Also graph for which “Programmer palette” with “for” loop was used shown incorrect results.
After removing “Programmer palette” counting was correct
test file: http://wrzucacz.pl/file/2121299493009
jpg version of test file: http://wrzucacz.pl/file/4761299493151
#2 Pubblicato: 07/03/2011 07:48:00
Gruppo: Moderator
Hello marcin,
Actually, there is an influence on your Iamp() function. You changed the variable "i" and used it as a loop variable. This way you've lost the imaginary unit. Advice: Do not use variable "i" as a loop variable if using complex numbers.
Numerical result
[MATH=eng]Iamp(225)=1.06*10^{-2}[/MATH]
Symbolical result
[MATH=eng]Iamp(225)—abs({10*(500000+225000*i*π)*(1000+225*i*π)}/{sqrt(2)*(225000*i*π*(500000+225000*i*π)+500000000*(1000+225*i*π))})[/MATH]
Before for loop
[MATH=eng]i—i[/MATH]
[MATH=eng]for(i,range(1,n_fx),el(tab_Iamp,i)←Iamp(el(fx,i)))[/MATH]
After for loop
[MATH=eng]i—101[/MATH]
[MATH=eng]Iamp(225)=7.12*10^{-3}[/MATH]
[MATH=eng]Iamp(225)—abs({10*(500000+22725000*π)*(1000+22725*π)}/{sqrt(2)*(22725000*π*(500000+22725000*π)+500000000*(1000+22725*π))})[/MATH]
