1 pagine (5 elementi)
Matrix Treasury - Matrix Treasury - Messaggi
There is more, working with matrices [3D, PseudoInverse ...]
Just a RemToDo.
The "Matrix Editor" Ecxel style is lovely, indeed.
At the end of this compendium, you will find a much
superior tool, directly from Smath, just make it
resident in the project work sheet and keep going.
Utilities Matrix Treasury.sm (284,57 KiB) scaricato 1556 volta(e).
Just a RemToDo.
... few more under construction.
I noticed something terribly grave while working the main sheet.
Explain: while working, Some "illegal" code [apparently], Smath toke
... very happy working well. Bad luck, on closing the work sheet
it zapped the entire work [turn it all blank at reopening]. Oh ! Hell
Good think, most of it I could recuperate from previous attached.
Any fellow experienced such a nightmare ?
I Underatand, it's a big chunck for Smath, but peanut Mathcad 11
I still have a 100 MB Mathcad 11 WS [graciously made dead by PTC]
Comments/suggestion/typos: always appreciated
Utilities Matrix Treasury [Locate Matrix].sm (21,92 KiB) scaricato 1344 volta(e).
Utilities Matrix Treasury [Rotate].sm (48,29 KiB) scaricato 1310 volta(e).
Utilities Matrix Treasury.sm (307,74 KiB) scaricato 1578 volta(e).
... defending the use of the "Matix Editor" conjointly to Smath is
"floccinaucinihilipilification" ... Does not belong to Navajo.
Utilities Matrix Pad [M,nc,nr].sm (18,04 KiB) scaricato 1311 volta(e).
ioan92 21/12/2015 18:56:00
Nice work, as usual
Unfortunately, this happens...
I've made this proposal, anyone who want to support/improve it, you have to register in the Bug Tracker System.
BTW seems you have found something that I have to change...
![2015-12-22 00_30_50-SMath Studio Desktop - [Utilities%20Matrix%20Treasury.sm_].png](/it-IT/files/Download/2gEY8v/2015-12-22-00_30_50-SMath-Studio-Desktop---[Utilities%20Matrix%20Treasury.sm_].png)
Wrotevery happy working well. Bad luck, on closing the work sheet
Thanks Davide for visiting and commenting. The "Why not nested" is simply because on closing,
either XP or Smath don't save the work sheet settings, completely.
I know about Autocad "AutoSave" but don't use AutoCad.
In my case, I didn't try XP Restore because of the time inprecision: it might have done nothing !
On delicate work sheets like "Matrix Treasury" I also save as copy,,, that one was scrapped too !
Your "AutoSave" proposal [link above] is quite welcome. Now convince Smath Developpers.
