Augmented matrix - unexpected SMath behaviour
Augmented matrix - unexpected SMath behaviour - Miscalculation of augmented matrix? - Messaggi
#1 Pubblicato: 19/07/2021 18:17:15
Jan Claeys
Jan Claeys
2 apprezzamenti in 25 post.
Dear all,
I'm currently writing a basic cam profile generation program in SMath, see attachment below.
Today, I encountered a behaviour I can't explain:
* On the last page, I create some X and Y values
* For some reason, the calculated values in the augmented XY matrix are not correctly calculated
However, calculation is correct when I add an extra field that has nothing to do with the actual calculation (field marked in red)
What happens here?
* SMath error?
* Programming error on my side?
Thanks in advance for any feedback, I love SMath and I would like to finish the program.
Kind regards from Belgium,
Jan
Cam engine - problem.sm (73,26 KiB) scaricato 1473 volta(e).
#2 Pubblicato: 19/07/2021 19:35:50
Hi Jan. The problem is that SMath try to eval functions starting with if to true or false. You can prevent that behavior with line( ), as in the attached.
Cam engine - problem.sm (73,74 KiB) scaricato 1537 volta(e).
janclaeys 20/07/2021 04:42:00
#3 Pubblicato: 20/07/2021 04:45:07
Jan Claeys
Jan Claeys
Hi Alvaro,
Thank you very much for your feedback!
This is certainly something I wouldn't have discovered by myself: muchly appreciated!
p.s. the program isn't ready: the formulas at the last page don't create the required cam profile yet, working on it ;-)
Kind regards,
Jan
